"Just make a new cable, you can buy the connectors for very little and a piece of ribbon cable, I use a bench vise to crimp them, takes just a few minutes to make a cable. Glad to hear you tracked down the problem though."
I have put it back together now, but the problem is that
IIRC that cable is soldered at the front panel end, and with a PTH board there is a very high risk of pulling off a pad on the topside, unless one can melt all 20 at the same time. I have a turret mill and could machine up a copper block with 20 holes on a 0.1" grid...
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
Anyway next time I will know where to look. You people have been incredibly helpful. I co-run a forum too (EuroGA) and it isn't an easy job!
"Yeah DSOs are expensive, but I was under the impression you already had the TDS scope? I've always been an analog scope guy myself but since acquiring a really good older Tek DSO it has become my primary scope. Being able to capture and examine waveforms is just incredibly useful."
The TDS scope is horrible. The user interface is slow. You turn a knob and it takes close to a second before anything happens. This applies to the commonly used stuff like vertical position. Who designed this (I've been doing HW and SW since ~ 1975) should be shot. Maybe it uses a 4004 running Java? And it wasn't that cheap - about GBP 1000. It was bought for vibration measurement in a light aircraft -
http://peter2000.co.uk/aviation/vibration/index.html - where I wanted a portable scope but the battery powered ones (well, the ones which wer not near-useless) cost a lot more. Also the screen resolution is rubbish so narrow pulses show up as a line of pixels hanging down from 5V, sometimes all the way down to 0V and sometimes halfway down, with the latter indicating that there is a short or bus contention etc. It's a toy... I hoped it would be generally usable but it isn't.
If I was buying a DSO it would have to be 200MHz at least and have a really high-res display. The RTB2004 looks like it would be nice but who knows whether the UI is fast.
Of course the storage aspect of a DSO is great. But then I see the way they load up the price if you want data analysis options
This is off topic now - there is the long RTB2004 thread. I wonder if that one can be bought as a base model and hacked to 300MHz?
BTW does anybody want hi-res (15MB) photos of the innards of my Tek scope before I put the covers on it tonight? I can put them on a FTP site, permanently.
