Author Topic: Tektronix 2465B oscilloscope teardown  (Read 713511 times)
Offline james_s
Re: Tektronix 2465B oscilloscope teardown
« Reply #1000 on: April 05, 2018, 05:24:32 pm »
It's possible that it's a fake that is not even a real FRAM inside. It could even be something like a microcontroller paired with a serial EEPROM, you never know with random Chinese parts. I got several Dallas SRAM modules that were obvious fakes.
Offline Miti
« Reply #1001 on: April 05, 2018, 11:14:37 pm »
It is possible but I would think is too much trouble, does it even make economic sense? I'll give it an X-Ray one day to see how many dies are inside.
Fear does not stop death, it stops life.
Offline BravoVTopic starter
  • +++ ATH1
« Reply #1002 on: April 06, 2018, 09:33:01 am »
I've read somewhere but forgot where, for those dodgy ones especially Maxim/Dallas BBSRAM products, actually they're genuine, but re-cycled and re-labelled.
Offline james_s
« Reply #1003 on: April 06, 2018, 09:26:42 pm »
I've seen both, old parts that have been relabeled, and counterfeit copies, confirmed by xray followed up by grinding into the thing. The copies had a completely different internal layout.
Offline usergen
« Reply #1004 on: April 07, 2018, 06:55:34 pm »
hi all and hope not to be OT, could anybody suggest how to remove the front panel knobs not having screws? I tried to pull them out with my fingers but they seem very tight and I'm afraid to break something if applying more force. thanks.
« Last Edit: April 07, 2018, 07:00:31 pm by usergen »
Offline usergen
« Reply #1005 on: April 08, 2018, 08:01:12 pm »
any feedback from you guys?  :(
Offline MarkL
« Reply #1006 on: April 08, 2018, 09:43:53 pm »
They do just pull off, but maybe after being on there for so long they are stuck.
Maybe warm the knob up a little (like with hair dryer, not a heat gun) before pulling on it?
Offline usergen
« Reply #1007 on: April 08, 2018, 10:12:29 pm »
tnx a lot MarkL, even for the picture!!
  • +++ ATH1
« Reply #1008 on: April 09, 2018, 09:34:51 am »
Also be warned, as sometimes not all knobs can flushed completely, like mine here.  ::)
Offline usergen
« Reply #1009 on: April 09, 2018, 02:28:23 pm »
Hello BravoV, I haven't tried to remove any yet but I'm a bit confused now, does it mean your knobs can't be entirely pulled off or do they can't be pulled in further? thanks a lot.
Offline cheeseit
« Reply #1010 on: April 09, 2018, 06:34:34 pm »
Its the latter and the same on my scopes with about 1-2 mm distance from knob to face.
Offline usergen
« Reply #1011 on: April 09, 2018, 07:00:18 pm »
all the knobs safely removed, thanks again guys.
Offline gregariz
« Reply #1012 on: April 09, 2018, 07:06:32 pm »
My advice after learning the hard way is that Tektronix knobs are really not meant to be removed. Really they are a weak point in an otherwise classic cro. They clip onto that inner plastic sheath and with a bit of age the clips in the knobs become very brittle and can break. If that happens often the only thing to do is to apply some glue and glue them back on - hoping you never need to remove them again. Some years back a fellow on the net bought up the old Tektronix stock and was charging a fairly heavy price per knob, but once you've broken a few you know why he did it.
Offline james_s
« Reply #1013 on: April 10, 2018, 02:30:42 am »
It's possible that the plastic shrinks slightly in addition to becoming brittle. That's a fairly common and rather annoying trait of plastic. It wouldn't take much shrinkage for a knob to get stuck on a shaft.
  • +++ ATH1
« Reply #1014 on: April 10, 2018, 03:05:55 am »
Although I haven't tried on mine, just thinking out loud on the idea about applying some plastic friendly grease before putting back the knob, but not making it too loose that they falling out by it self during use.  :-//
Offline Miti
« Reply #1015 on: April 11, 2018, 01:22:25 am »
Ok, I have the X-Ray. It seems to be one die inside, no evidence of MCU and EEPROM. It's either a crappy part or 2445 cannot work with FRAM. I'm inclined towards the first.
Offline pquadrat
« Reply #1016 on: April 12, 2018, 07:51:35 am »
I've got another 2445B (with new style A5 board), defective, no trace or anything on the CRT, but otherwise it is working fine, all buttons/LEDs working, triggering on signals etc.
After swapping some boards with another 2554B, I could locate the fault on the A1 mainboard. Removing the horizontal and vertivcal deflection cables did not give an image, so my guess was, that the error could only be the Z (intensity) control. And it was U950, which is the Z axis control chip. With the U950 from the other 'scope, all works fine.
Does anyone here has a working U950 (155-0242-01) chip for sale? Preferred in Europe?
« Reply #1017 on: April 12, 2018, 07:58:56 am »
At the foot of this page there's a link to a 27 MB cross ref file of Tek parts.
http://www.sphere.bc.ca/test/tekequiv.html
It might be commonly available so check what it is.  ;)
Out of office and unavailable for a few days.
The following users thanked this post: GerryBags
Offline pquadrat
« Reply #1018 on: April 12, 2018, 08:17:59 am »
It is one of the custom Tek chips.
And I was able to get one here in Germany, so no longer looking for one.
« Last Edit: April 12, 2018, 10:24:38 am by pquadrat »
Offline neo
  • The specialist.
« Reply #1019 on: April 18, 2018, 09:53:54 pm »
Anyone know what it means when a 2465B bleeps its front lights? Fan's running and it starts up like normal until it starts that, the blinking of it's front light i mean.
« Reply #1020 on: April 19, 2018, 12:06:42 am »
Start with the basics and work from there. Make absolutely certain all your supply voltages are within spec as far as voltage and ripple. J119 on the main board is a convenient location to check them. I don't have the manual in front of me at the moment so I can't tell you what page it's on.
Offline neo
  • The specialist.
« Reply #1021 on: April 19, 2018, 02:45:33 am »
So then, the blinking points to nothing specific then, therefore the long way it is. Thank you that is exactly what i wanted to know, the 70s were easier to work on  :-DD
https://www.eevblog.com/forum/repair/tektronix-2465b-repair/
Offline andy2000
« Reply #1022 on: May 04, 2018, 02:45:37 pm »
I recently started working on my late model 2445B.  It had the usual leaking caps on the A5 board, plus some open traces.  I've taken care of those problems, and it's basically working, but there's one peculiarity.
If I use auto scale, or any of the auto measurements, it momentarily blanks the trace (I assume this is normal), but when it's done, the trace is either very dim, or invisible.  I can get the trace back by turning up the intensity, but the same thing happens again if I repeat the auto operation.  After enough times, it needs to be near maximum to get a visible trace.  Reducing the intensity control to minimum, and turning it up restores its normal range.  I assume this isn't normal.
Online tggzzz
« Reply #1023 on: May 04, 2018, 02:50:35 pm »
It happens on my 2445B. I have presumed it is because it doesn't "know" how bright to set the beam, and so adopts a conservative value.
Offline pquadrat
« Reply #1024 on: May 04, 2018, 04:35:58 pm »
I tested it on a late 2465B and a late 2445B, both set the intensity to the same intensity as adjusting the intensity knob to the mid-position. On one this is fine, on the other it is to dark. But both are equal to the mid-position if adjustet by hand.
Re-adjusting grid bias and the other intensity adjustments (see the service manual) so that mid-position of the intensity pot gives a "normal" intensity will help.
The following users thanked this post: BravoV
