I do not think so... Fine control was not added IMHO.
It seems that this scope is suitable for you if you need quite cheap four channel scope and you do not need good VPO performance or high waveform update rate. Also the search function might be useful. You have probably seen Dave's video, have you?
Note the crap function generator. Nowadays you can buy Rigol DS2000 with arbitrary generator.
On the other hand, GW Instek will last longer IMHO. It does not have such a powerful hardwware, but it should be durable.
And I think that even that expensive GDS-3000 series has no fine vertical control.
Contact your authorized dealer for more info.
