My first and only Fluke meter so far is the 233 - Remote Display True RMS. It has all the functions I would need and the radio linked head is pretty interesting. Problem was that the unit has a heart beat between the body and the head, even when "off". Research indicated this is because the meter can be turned on remotely. When the head is installed on the body it uses IR rather than RF to save the AA batteries (2 in the head and 3 in the body).
Because I use the meter on the bench for hobby work and not in the field, it didn't get use a lot and should last for months with intermittent use. I was finding it dead within 2 months. Research uncovered the heart beat feature as the reason. For my purposes, I didn't purchase the best option - oppps. No chance in selling it, lots of eBay entries already.
I set out to hack in a toggle switch on both the head and body between the battery terminals. This would give a HARD off rather than the soft off while running heart beat.
First goal was to hack it with significant modification. This worked for about a year and proved the concept.
For the long term hack, I opened up the meter and installed micro toggles inside and sealed up to maintain the ruggedness of the unit. So far it has been solid provided I don't forget to turn off the toggle switches.
The setup has both switches in line so one swipe gets them both. This was a significant improvement over the first attempt.
