Hi
If somebody wants to get the PCI working on a Tek TLA704 below you can find the steps to accomplish that:
1. Unsolder all the pins for the PCI connector on the board and put in a PCI connector (120 pin)
2. Populate R25 and R23 with a 0 Ohm resistor (5 and 3.3V) (found on the top of the board near the PCI Connector)
3. Populate R4 with a 33 Ohm resistor (PCI IDSEL) (found on the top of the board near the PCI Connector)
4. Populate R165 with a 33 Ohm resistor (PCICLK) (found on the bottom of the board on the opposite side of the PCMCIA connector under the crystal)
This will get the PCI working BUT the BIOS will not assign any IRQs to the PCI board and when booting you will get this:
Warning: IRQ not configured - Pci at slot 01
Bus:00, Device: 0E, Function:00
System Configuration Data updated
Press <F1> to resume, <F2> to Setup
regardless of the settings you do in BIOS.
If somebody could take a look at the bios (maybe someone has RFDes contact info) and see it they can change/mod it to support IRQ assignment it would be awesome
The PCI cards will be detected in Windows but it won't start. Windows will report that the device does not have an IRQ assigned to it by BIOS
Attached you can find the latest bios 1.00.14
For your info when I started this I wanted to add a PCI USB card so that I can add a soundcard to the device in order to play some old games on the device with sound
