I find the documentation on the AWG a bit lacking.
Perhaps someone more familiar can tell me if it can do this;
For aligning an old FM radio, the specified signal is 10.7Mhz FM, modulated with a 60hz sine wave, and 450khz sweep. Modulating the signal is no problem but I can’t figure out how to add the sweep into the mix. I know there is a sweep function available but it doesn’t appear to be available simultaneously with modulation.
Edit: It might be better to share the instructions because the nomenclature does not translate well to the Rigol AWG menus.
“Use frequency modulated signal with 60 (then there is a sinewave symbol) modulation and 450 khz sweep.” Then under Signal Generator Frequency it says “10.7Mhz (unmod.)”
The instructions don’t make sense to me as they call for modulation and unmod. in the same context. Either way, I don’t see a sweep setting available unless the Rigol “Deviation” is equivalent, but still no joy as 1khz is the max.
Can someone educate me?
Thanks,
Jeff
