Anyone here has the schematic for the attenuators of the TDS 744A/754A/784A?
I'm now a happy owner of a 744A that became a 784A by removing the R1061 resistor from the back of the acquisition board.
Works great apart from the damaged LCD shutter and a problem with the CH1 attenuator. The guy on ebay said something about purple spots on the screen and I was unfamiliar with the LCD shutter technology and therefore thought that somebody was playing with magnets or spilled some ink as I believed that Tek used a normal color CRT.
But I can live with that, since the CRT itself is still in perfect condition and a few purple spots don't really bother me in seeing the traces on screen. If the problem gets worse, I'll simply cut the shutter off and use it in monochrome white mode. Not really nice, but usable.
The other problem I'd like to fix is the broken attenuator of CH1. The relays are still clicking, but I loose the signal if I switch between 100mV/div and 200mV/div and only see small capacitive spikes in 200mV/div mode.
This makes me think that those numerous gold pins in the plastic connector, the amp, ADC ... of CH1 is fine and one of those 4 yellow relays has bad contacts. Switching between AC/DC doesn't change it.
Since there's a black chip on the ceramic assembly and I'm unsure if it has anything do do with the relays, I don't want to use my usual method of cleaning relays by applying 20V@100Hz _|¯|_|¯|_ from a function generator for a few minutes to a few h until the oxides on the relay have vibrated off.
Maybe someone has the schematic, so I can see which relay I need to torture or unsolder
