Hi there,
I have a
Tektronix TAS 465. I can easily adjust the Volts/Div at a coarse scale, such as 1 V, 500 mV, 200 mV, 100 mV, 50 mV, etc. How do I have more fine control of the Volts/Div? I noticed there is a "VAR On/Off" setting in the Vertical Menu, but turning that on doesn't change the behaviour of the Volts/Div dial.
I've tried searching through the manual that I've linked, but I can't seem to find instruction on how to set the Volts/Div to something like 735 mV, for example.
Is anyone here familiar with this line of oscilloscopes or is able to find instructions on how to do this?
Thanks!
