It's an p4 2,8ghz with 2gb of ram
When i'll re open it i'll take some pictures ... still need to use it while it doesn't create / have too many problems
I ordered at digikey a ds1245y-120 pdip around 50$ CAD ?? the tricky part will be to remove that chip ... will need an vacuum desoldering tool
Did read thru all this thread
![Phew :phew:](https://www.eevblog.com/forum/Smileys/default/phew.gif)
for the nvram backup script, i found out i can force a factory reset and apparently put back stuff in the nvram, i have no experiences for these kind of stuff loll but feel relieved.
Found out that the motherboard is in DHCP mode for the lan, and apparently or it seems the TEK Scope software will push an ip address ??
Pushed XP Sp3 pack into it without problems ... did put XP in classical mode with the ''best optimal mode'' in the performance settings
Managed to find an usb hdd dock with Ide and sata ports who can clone hard drives and i'll do an hdd image just in case
May be tempted to put an pata ssd in it to slightly optimise to boot time, but mostly to get rid of an aging drive
And i did found out i have a slight touch screen offset, even with the calibration utility, it can't be corrected.
From the middle screen to the bottom, i have around 3 to 5 mm offset in the mouse pointer ...
In my case all SPC tests passes .... but sometimes the scope hangs without reasons, have to restart it ?
You have partial service manual for the tds7000 series, but haven't found a complete manual if there is one ?? Links ??
