if you backed theses folder, you have the folders who contain the needed drivers
for the gpib interface you need the drivers setup
for the dallas battery it is on the power pc board under the computer motherboard dallas ds xxxxx
well since its a used scope you've bought, do you have an idea of it's history / checkups / maintenance ?? dust cleaned ?? a checkup has to be made
if windows boot fine minus some errors, you have to check device manager
you can kill the scope software if with a keyboard crtl alt del you invoke task manager and kill the tekscope running task
i have a 7404 non B, who seemed fine and the next day, hell happened, took me 2 weeks to re-install everything and find appropriate hardware to do re-installations, win2k was not working, endless loop, ended up with Windows ME, with all the crap removed
motherboard (su 810) is hardware locked, you can not connect all you want, or all you need ... hard drive size too etc ... the cd-rom would not read burned cd's, finding originals was tough, changed to a 1ghz cpu, and doubled the ram with a mix of pc133 sync and pc100 sync (would not accept the same sizes and speed
you have to read the tds7k thread, its huge but the last pages have more recent informations ...
the power pc dallas battery died, lost the vxwork configs ... tekscope was hanging up and crashed, spc errors due to eeprom corruption ...
now fully working, spc fine etc ...
its a big beast you bought, with some quirks you should not have tampered with it, unitil you had done an hdd cloning
