pls not being rude can you make some efforts to show us some correct pictures, orientation etc ....
the picture doesn't help at all
and like the first thread page, you push any keyboard key to stop the countdown, and you type the minus c not the caps C .... you had this in vxworks if you where successful to stop it
[VxWorks Boot]: ?
? - print this list
@ - boot (load and go)
p - print boot params
c - change boot params
l - load boot file
g adrs - go to adrs
d adrs[,n] - display memory
m adrs - modify memory
f adrs, nbytes, value - fill memory
t adrs, adrs, nbytes - copy memory
e - print fatal exception
n netif - print network interface device address
N - set ethernet address
type c and enter, you should begin to do the settings like this : and your entries should be after see in bold, at first youlle se what they are, and after in bold you put yours ....
[VxWorks Boot]: c
'.' = clear field; '-' = go to previous field; ^D = quit
boot device : sm
smprocessor number : 0
0 host name : host
hostfile name : c:\vxBoot\vxWorks.st
c:\vxBoot\vxWorks.stinet on ethernet (e) : 192.168.0.2:ffffff00
192.168.0.2:ffffff00inet on backplane (b): 192.168.0.2:ffffff00
192.168.0.2:ffffff00host inet (h) : 192.168.0.1
192.168.0.1gateway inet (g) : 192.168.0.2
192.168.0.2user (u) : anonymous
anonymousftp password (pw) (blank = use rsh): anonymous
anonymousflags (f) : 0x1000
0x1000 some had to put
0x1008 in my case it did not help
target name (tn) : target
tds7000 this one should be
tds7000, otherwise tekscope will not save settings
startup script (s) : c:\vxBoot\dio_rst.vsh
c:\vxboot\topscript.hwother (o) : this one play tricks had to put
0x0 or
0x0000 tekscope had some problems, some have put
0x1000 ![Huh? ???](https://www.eevblog.com/forum/Smileys/default/huh.gif)
