Managed to get a tds7404 running, Radisys Su810 crap Mobo, 256mb of ram
I had to buy 2x hdd, i put one as the cd-rom substitute with all the needed stuff in it
Put an Celeron 1.1Ghz instead of the lousy 566 Mhz one, waiting for more ram
Installed win98se with tekscope 2.55 it works, but i have spc errors to iron out
EDIT now on
Win Me and Tekscope v2.53
Made an raw image backup of win98se no tek installation(s) This is what works for me in the nvram contentboot device : sm
processor number : 0
host name : host
file name : c:\vxBoot\vxWorks.st
inet on ethernet (e) : 192.168.0.1:ffffff00
inet on backplane (b): 192.168.0.2:ffffff00
host inet (h) : 192.168.0.1
gateway inet (g) : 192.168.0.2
user (u) : anonymous
ftp password (pw) : anonymous
flags (f) : 0x1000
target name (tn) : tds7000 -----> i've been told to keep it like this, if not, tekscope does'nt save some settings ??
startup script (s) : c:\vxBoot\topscript.hw
other (o) : 0x0
Still have doubts on the
flags and
other sections,
if i put something else in the
flag like 0x1008, tekscope stalls
if i change
other setting like 0x1000 tekscope starts but no traces of ch1 ch2 .....
For those who have low brightness on the lcd, you have to get the right chips tech 9000 drivers, in the advanced section you have gamma correction ...
I have searched tons of drivers and all i could find on xdev's site and help from others, all the iso's, windows installs etc ...
had to install unofficial usb drivers packages to get some usb keys to work, very picky on brand or storage sizes.
The touch screen is working as an HID device, i can not calibrate it ?? (slight offset, but workable) i have to dismantle the scope to check which company did the touchscreen interface on COM2
![Huh? ???](https://www.eevblog.com/forum/Smileys/default/huh.gif)
not sure i want to go there ...
Win ME All seems to work, divers to find, mostly the video ones, the chip and tech 9000 is very important in my case, if not i got garbled traces, and low brightness (gamma set at 2.0)
attached here, picky on usb drives brands and sizes
Win2k I got hw resource conflict between the pcmcia slots and the lan interface (was discussed here) and Tekscope 2.5.3 or 2.5.5 would not give scope traces on the screen
XP Sp3 Stuck in a continuous boot loop an minus 39 minutes, absolutely can't finish the setup ?? even upgrading from Win ME or Win2k, I wanted to read the vid's and pid's of the hardware
Win7 as an extreme measure, not even sure that will work loll NOT
Will try with an ordered motherboard based on intel 815 from a gateway e-3400 ... well see, for sure the motherboard metal frame need some mods, one more hole for an audio connector, and maybe one db9 port ![Huh? ???](https://www.eevblog.com/forum/Smileys/default/huh.gif)
EDIT Well its a pretty tight fit in length, the metal frame is not compatible for sure, the pcb is longer than the Radisys one, and sadly
![Broken! :-BROKE](https://www.eevblog.com/forum/Smileys/default/smiliey_scope_broke.gif)
the scope doesn't want to power up, the led power button turn red, and this one would accept an 1.4Ghz Tualatin
![Banging Head |O](https://www.eevblog.com/forum/Smileys/default/bangheadonwall.gif)
Even on NLX standards, something must be missing for the gateway, maybe a supply line ?? it was a very low cost purchase
![Phew :phew:](https://www.eevblog.com/forum/Smileys/default/phew.gif)
Good infos here :
https://github.com/exit-failure/tds7000/blob/main/NVRAM/README.mdthks to this thread
https://www.eevblog.com/forum/repair/boot-problem-on-tektronix-tds7404-scope/to reformat some eeprom ... cleared some problems
all spc pass and self cal pass oooofffffffffffffffff what a ride
