By carrying out multiple tests I managed to partially load the program but it stops as shown in the quote below.
![Confused :-//](https://www.eevblog.com/forum/Smileys/default/confused0024.gif)
Does anyone understand what this means ?? I don't have a topscript file on my disk ??!!
Initializing backplane net with anchor at 0x1e80000... done.
Backplane anchor at 0x1e80000... Attaching network interface sm0... done
done.
Attaching network intPC1 dio device driver installed
erface lo0... done.
Attaching DIO client... done.
Loading c:\vxWorks.st...1771964
Starting at 0x200000...
Initializing backplane net with anchor at 0x1de0010... done.
Backplane anchor at 0x1de0010... Attaching network interface sm0... done
done.
Attaching network interface lo0... done.
Adding 6006 symbols for standalone.
]]]]]]]]]]] ]]]] ]]]]]]]]]] ]] ]]]] (R)
]]]]]]]]]]]]]]]]]]]]]]]]]]]]] Development System
]]]]]]]]]]]]]]]]]]]]]]]]]]] VxWorks version 5.3.1
]]]]]]]]]]]]]]]]]]]]]]]]]] KERNEL: WIND version 2.5
]]]]]]]]]]]]]]]]]]]]]]]]] Copyright Wind River Systems, Inc., 1984-1997
CPU: Tektronix HPP - PowerPC 740. Processor #0.
Memory Size: 0x2000000. BSP version 1.0.3.5.
WDB: Ready.
usrNvFsInit: NAME=/nvram BASE=0xfd0ff100 BPRB=412 BPRT=8 NBR=8 BO=0
nvfs: STATUS: Mounting existing NVRAM file system
KERNEL: THERMAL CONTROL INITIATED
Executing startup script c:\vxWorks.st ...
dbFsIoctl: invalid code 3
ELF...
syntax error
Done executing startup script c:\vxWorks.st
KERNEL: RUNNING TIME SLICED AT 10 TICKS PER SLICE!
-> [/quote]
