Author Topic: TPI-153 teardown  (Read 3929 times)
Offline fqahmad66Topic starter
TPI-153 teardown
« on: February 15, 2014, 07:05:48 pm »
My TPI-153 teardown - Part 1
Re: TPI-153 teardown
« Reply #1 on: February 15, 2014, 07:11:09 pm »
part-2
Offline retiredcaps
« Reply #2 on: February 15, 2014, 11:49:09 pm »
Thanks for the pictures.  Better late than never!  ;)
These meters are also made for Snap-on and Bluepoint.  I always wondered what it looked like inside.
I can't find any info on the Summit-8 IC.  I can't even find the company Summit (presumably based out of Japan)?
I also can't think of which Korean manufacturer who might be making these for TPI/Snap-on/Bluepoint.
« Last Edit: February 15, 2014, 11:53:35 pm by retiredcaps »
Offline Wytnucls
« Reply #3 on: February 16, 2014, 08:27:32 am »
Summit/TPI is a small Korean multimeter company (53 employees) based in Inchon.
The DMM ADC is probably a relabeled Japan product.
http://www.alibaba.com/trade/search?fsb=y&IndexArea=product_en&CatId=&SearchText=summit+multimeter
http://www.summit.co.kr/product/pro02.htm
« Last Edit: February 16, 2014, 08:44:36 am by Wytnucls »
« Reply #4 on: February 16, 2014, 11:05:30 am »
I bought it from digikey couple of years back. Still gives accurate readings..checked it with 0.05% resistors. The fuses are unmarked but 600V is punched on caps. I am happy with it..particulary when it is powered by 2AA cells.
« Last Edit: February 16, 2014, 11:08:58 am by fqahmad66 »
Offline retiredcaps
« Reply #5 on: February 16, 2014, 04:42:50 pm »
Thanks for the links.  I would not have thought of using alibaba as a search engine.
Offline retiredcaps
« Reply #6 on: February 16, 2014, 04:52:24 pm »
If you like it, that is all that matters.
I'm a fan of the AA meters as well, but you have to be aware of potential battery leaks.
I noticed the 153 manual states 200 hours battery life which would imply a 12mA current consumption assuming 2400mAh AA alkaline.  At 12mA, that would be more than double the Ideal multimeter in Dave's $100 multimeter shootout.
