Author Topic: Tek 2465A -8V -5V too low  (Read 1531 times)
Offline GalenTopic starter
  • Country: cn
« on: October 30, 2019, 11:39:38 am »
I got a Tek 2465A, no trace. Sometimes, trace appear, but always 1 line, even I input signal.
As first attempt, I measured J119 voltage, found the +10V is right to the point, and most others are also within limit, except the -8V and -5V, I got -4.7V and -2.9V respectively. As per the SM, should fix the -8V problem first. I checked the -13.1V (before regulated to -8V), it's -8.7V only.
Anybody in this forum, has the experience to fix this problem, your advice is very appreciated. Thanks a lot in advance.
Galen
Delighted when problem fixed
Offline tggzzz
Re: Tek 2465A -8V -5V too low
« Reply #1 on: October 30, 2019, 11:49:46 am »
You'll find the answer here: https://www.eevblog.com/forum/repair/tek-2465a-8v-5v-too-low/msg2761426/#msg2761426
Or use the search box at the top right.
