Thank you Shahriar
. I was looking for a spectrum analyzer that supports harmonic mixers. I found E4407B with AYZ option that someone wanted to sell with the "LO unlock" error. Three hours with youtube
and your two episodes about ESA-E and I was sure I could do it. I have other spectrum analyzers, 85024A probe, generators, VNA etc but I have not bought broken measuring equipment before.
The same day when I ordered this E4407B, I also ordered CLIP manual for ESA-E and HMMC-3124/1GC1-4207 :4 frequency divider (I found in China).
The first came E4407B. In my case, the divider lost its signal if the LO frequency was greater than 6 GHz. I also had to replace the M4T28B Timekeeper battery and the volume knob were missing. I found the battery and the gray knob locally. Today a parcel with a divider chip arrived. A large hot air blower was needed because the hot air from my soldering station could not warm up enough. The effect is easy to predict. The next ESA-E had :4 damaged divider and has been repaired (+1 for statistics). My new chip is not signed with the Agilent name (probably Avago production) and I hope it will live a little.
Shahriar, you are the man!
