Author Topic: Teardown & Repair of a SRS DS345 30MHz Synthesized Function Generator  (Read 2155 times)
Offline HugoneusTopic starter
    • The Signal Path Video Blog
You can watch the video here: [30 Minutes]
youtu.be/SKUT11VDuXc
More videos at The Signal Path:
www.TheSignalPath.com
Offline Arjan Emm
Re: Teardown & Repair of a SRS DS345 30MHz Synthesized Function Generator
« Reply #1 on: August 14, 2017, 01:40:03 pm »
Hello Shahriar,
thanks for the great videos i watch them all the time.
I noticed something in your video about the sync cpr error. It might not be a level problem, but actually a synchronization error between the sync and function outputs.
At 4:40, after the generator started up without error, the scoop shows the two outputs perfectly in phase/sync. The zero crossings line up nicely.
At 6:14 the sync out put is slightly ahead of function output. This is only a little bit before you turn the generator off and on and the error shows the first time.
At 7:38 and 8:24 with the error the sync is delayed compared to the function output. After fiddling with the pot the error disappeared and at 18:51  the two outputs are perfectly aligned again.
« Last Edit: August 14, 2017, 01:44:32 pm by Arjan Emm »
« Reply #2 on: August 14, 2017, 06:41:58 pm »
Hello Shahriar,
Interesting! Thanks.
Offline bitseeker
« Reply #3 on: August 14, 2017, 07:16:01 pm »
Thanks, Shahriar. That was a fun puzzle.
I wonder what that long bodge resistor(?) is about on the upper PCB.
« Reply #4 on: August 15, 2017, 03:34:22 pm »
Yeah, not a pretty sight! Seems to go to the ribbon cable.  :-//
