Author Topic: Hack Proskit MT1706 PeakMeter PM 18C , Bside ADM08A  (Read 1574 times)
Offline rafik23Topic starter
  • Country: dz
« on: January 21, 2020, 12:59:54 am »
After going home i take the multimeter it is a PROSKit MT 1706  and start reading  again and again on forums  so I decide to teardown it and make an analysis of data stored in eeprom and hack it EEprom from originaly dump appears like this
911672-0
we see on its dump no thing extra or strange so i decide to make an excel file to analyse data stored in eeprom
i take an hexa from editer and past it on data in excel and i see the max range , and all data relative to manufactor
911676-1
I take my old programmer type CH341A and its onboard IC  clamp, after more reprise it didnt success reading then i went to solder on PCB
 911680-2
and starting reading and modifing data function from 01H to 40H like we  see on my older post there is function above 30H
and the result is
 RANGE    Code Func   position Hex
600 mVDC       01   08 03
60 VAC       0A   08 09
600 VAC       0B   08 0A
750 VAC       0C   08 0C
60 mA DC       29   08 0E   0F   mA DC AUTO   11
600 mA DC    2A   08 0F
60K OHM       17   09 09
600 OHM       15   09 0B
NCV               22   08 05
6 VAC       09   08 08H
Live               24   08 0D
Hz               1D   8 0F
Cont               14   8 1C
1000VDC       06   9 00
600 VDC       05   9 01
60 VDC       04   9 02
60 A DC       2E   9 03
6 VDC       03   9 04
60 A AC       30   9 05
600mA AC       2C   9 06
6 M OHMS       19   9 07
600KOHMS    18   9 08
6K OMM       16   9 0A
° C                1F    9 0D
Hfe               21   9 0E
Diode       13   9 1C
600 mVAC       08            07   AUTO   33
60MOHM       1A
600MOHMS    1B
Cap                1C
%               1E
°F               20
600 uA DC       25      0D   µADC AUTO
6 mA DC       26
600 uA AC       27      0E   µA AC AUTO
6 mA AC       28
60 mA AC       2B      10   mA AC AUTO
6  A DC       2D      11   A DC AUTO
6  A AC       2F              12   A AC AUTO   36
60 uA DC        31
60 uA AC
INFO the function is mentioned in right is the same range in AUTO mode
after this i change max range to 9999 count and over range OL is 10000
911684-3
after this i try to add some button like REL/RS232 and other but nothing hapened when switching.
I think for automatic ranging there is something added on data in the header of eeprom
Example : we see
 911688-4
it not described on DTM0660 datasheet
so i add on some range the same range in automode but i discover only Amper range can be in auto mode ( no volt no Ohms )
here is structure of 80h and BFh
0x80H 00 00 24 01 00 22 1a 19 09 0a 0b 21 0c 31 29 2a 06 05 04 2e 03 30 2c 2b 18 17 16 15 14 1f 1c 1d
0xA0H 00 00 00 07 00 00 00 00 00 00 00 00 00 0d 0f 00 00 00 00 00 00 00 00 10 00 00 00 00 13 20 00 1e
I have added
600mvAC on 600mvDC (not modified but ADDED)
60mADC AUTO on 60 mA DC
600µADC AUTO on 60µA DC
that's all
any other idea ? or suggestions ?
dumps of orginal and modified
« Last Edit: January 21, 2020, 01:15:28 am by rafik23 »
