Author Topic: Help identify this device.  (Read 2936 times)
Offline PaskyTopic starter
« on: April 13, 2015, 03:43:09 am »
This is the best I could do using my magnifier and camera.
It appears to read:
8GM3052 or 8GM 3G52 or BGM 3052/3G52
XMS
1415C
I believe it's an Op Amp but cannot find any datasheet given the print on the chip.  Thanks for any help.
« Last Edit: April 13, 2015, 03:44:48 am by Pasky »
Re: Help identify this device.
« Reply #1 on: April 13, 2015, 03:52:08 am »
Also my apologies, wrong section.  I wanted this in the projects and designs sub forum  :palm:
« Reply #2 on: April 14, 2015, 05:50:31 pm »
Still trying to find this, and if a moderator would please move this to the appropriate sub forum   :-[
Offline Muxr
« Reply #3 on: April 14, 2015, 06:21:37 pm »
You will get less noise on your camera if you can get some more light on the subject.
Offline coflynn
    • Colin's Homepage
« Reply #4 on: April 14, 2015, 10:39:30 pm »
I think SGM8052, the datasheet specs in the MSOP8 package the marking being "SGM8052XMS" which aligns with most of the markings you've got, and falls in line with the op-amp assumption.
« Reply #5 on: April 15, 2015, 04:26:36 am »
Excellent.  Thank you sir.
