I am writing some small scripts to control the N9020A signal analyzer. Basically as a learning experience, when needed for "serious work" I will use the scripts as a starting point. The Spectrum Analysis and Phase Noise modes are well defined. The Noise Figure mode quite less so. I have the N9020A programming manual (abt 3300 pages) but it does not really cover the Noise Figure mode. In particular I can not find the correct commands to load the CAL/MEAS ENR tables from MMEM. I can operate the SA manually of course but that does not really give a clue how to program the instrument. Is anyone familiar with the NF mode and is there a programming manual available that I have not found (on Keysight's website)?
Thanks in advance,
Harke, PA0HRK
