Author Topic: Teardown: Amprobe AM-270 Digital Multimeter  (Read 47428 times)
Offline multiJ
  • Country: gr
Re: Teardown: Amprobe AM-270 Digital Multimeter
« Reply #25 on: November 28, 2012, 09:53:49 am »
I contacted them (tequipment) a couple of weeks ago and they said they have "a minimum $300.00 international order requirement". Go figure  :=\
It would have been great if AM-270 was available for sale in Europe  ^-^
I live in Europe and got it for 90$+35$ shipping from Tequipement.net. It took 10 days more or less, half of that before departing the shop.
Offline dr_p
« Reply #26 on: November 28, 2012, 05:36:14 pm »
I just went ahead and placed the order, payed by Paypal and it all went smooth. While watching the video and pictures on their site I noticed that there is also an AM-270 without bar-graph , so I confronted them and they ensured me it has the bar-graph version. It was well packed, and I'm very happy with it.
Offline multiJ
  • Country: gr
« Reply #27 on: November 28, 2012, 06:27:35 pm »
Thank you very much for the heads up, I will check this out
Offline FenderBenderTopic starter
    • The Solid State Workshop
« Reply #28 on: November 29, 2012, 12:07:52 am »
It's called an AM-250. All AM-270s have bargraphs.
Offline multiJ
  • Country: gr
« Reply #29 on: November 29, 2012, 10:29:39 pm »
Would love some pictures and short review too, to compare this with Amprobe DMMs :)
I have just got myself a Brymen BM-257. I will post some pictures and perhaps a short review if anyone's interested. http://www.brymen.com.tw/product-html/cata250/Bm250s.htm
Yes, please!!!
Offline dr_p
« Reply #30 on: November 30, 2012, 08:59:08 am »
This video is from tequipement's site: notice the lack of 4 buttons and bargraph ;) And it says AM-270 TRMS on the meter!
« Last Edit: November 30, 2012, 09:04:33 am by dr_p »
Offline retiredcaps
« Reply #31 on: November 30, 2012, 09:13:47 am »
The same video is on amprobe's website
http://content.amprobe.com/video-dmm/Amprobe%20CAT%20IV%20Digital%20Multimeter.html
but the high definition pictures says "w/Bar-graph Display"
http://content.amprobe.com/HighResImages/am-270.jpg
Offline iloveelectronics
  • Country: hk
« Reply #32 on: November 30, 2012, 09:23:44 am »
They don't even look like the same meter. One has 8 soft buttons while the other only has 4! Confusing...
My email address: franky @ 99centHobbies . com
My eBay store: http://stores.ebay.com/99centhobbies
Offline cybergibbons
« Reply #33 on: December 01, 2012, 09:00:09 pm »
Pretty much my experience as well, though I got raped on customs charges.
Offline dr_p
« Reply #34 on: January 04, 2013, 02:21:03 pm »
Ok, been using this for some time and I've got things to tell you:
To silence the beeps when pushing buttons, one can hold Hz button while powering on via rotary selector. When the meter enters auto power off, one can wake it up by pressing any button, not just the select button like the manual says. But surprise-surprise, the beep is now ON, so I'm forced to rotate the selector to OFF, then desired range again while holding Hz (the usual way).
Now I accidentally found that if you wake it up from auto power off by HOLDING the Hz button, meter says "dsbld" or whatever it usually says (e.g. disabled beep) and beep is still OFF.  :-+
Hope it helps some people. Funny fact: I was so happy I found this out and my sleeping GF won't be bothered by the beeps that I reverse mounted an electrolytic cap (100uF, 50V connected to 27V). It was like 1:00 AM and I was troubleshooting some analog stuff  :-/O. 40 seconds later I smelled something heating up and glanced at my MAVO35 just to see it at 10mA and then violently shoot to full scale(100mA) :bullshit:. I touched my 2 ICs but thy were ok, then I spotted the cap bulging in my face. I mean like 20cm away. First thing that went through my head was UNPLUG THE SCOPE, I JUST BOUGHT IT!!!  :palm: Don't look for any logic in that, it's not like it will ever get electrically damaged by a bursting cap :-BROKE. I managed to unplug it and just started turning my head away when it exploded in (almost) my face. I'm totally fine, thank you. %-B
The moral is: leave the beep on, it saves you from caps exploding in your face.  :scared: :-DD |O
« Last Edit: January 04, 2013, 02:31:36 pm by dr_p »
Offline jhufford
« Reply #35 on: May 17, 2015, 07:56:32 pm »
So after a few years of using this meter, any final verdict? Is it suitable for general electronics work or only for electricians? From the specs it looks pretty good for electronics work. It has a 50mV and 50 Ohm and 500uA range and quick continuity tester...
I'm comparing it to the BK2970B or 2712 . But the BK doesn't have temperature and its beeping when turning the switch is darn near a deal breaker. Duty cycle is about the only thing missing from the 270 and it's frequency bw is only 125k but good enough for quite a few of the switching circuits I do, I can use the scope for anything higher than that.
I tend to do an odd smattering of projects, from battery power microcontrollers to high-voltage with flyback transformers. I thought the the am-270 might suit nicely and be a nice replacement for my <$50 ideal meter.  (or might the BK and a separate temperature meter be best?)
Thoughts anyone?
Offline Lightages
  • Canadian po
« Reply #36 on: May 17, 2015, 08:36:08 pm »
It was a great buy when it was only $90. Now it is $105 so not quite as nice a deal but still good. I would still recommend it for anyone who needs a well built, safe, and accurate meter for around $100. I don't have one but it is the same as a Brymen BM815. I haven't heard anyone complain about the 270 except for the bad back light.
Offline dr_p
« Reply #37 on: January 11, 2016, 08:59:07 pm »
I did a backlight mod today - replaced all 4 LEDs with high efficiency red ones. Whites would not even light up, as voltage before the resistors seems to be 2.4V. I couldn't be bothered to research more, so I just put the red ones in and they are clearly more bright than the stock green. Also added 3 layers of matte film from a broken LCD screen. The one that looks like sandblasted glass. I tried to space them referenced to each other, as to maximize the light dissipation.
For reference, stock backlight is very bad, similar if not identical to this Brymen: https://pbs.twimg.com/media/BCiSbY8CMAAGMDZ.jpg
I also added some pictures with the areas that the OP missed - main chipset and the back side of the PCB.
« Last Edit: January 11, 2016, 09:03:25 pm by dr_p »
Offline Johnny Electron
« Reply #38 on: August 25, 2016, 04:49:42 am »
Just to add info for new buyers which may be searching these old threads, the backlight is now fixed!  It is now a nice orange like the brymen meters when the 's' was added to their model numbers.
The following users thanked this post: onroadgoat
Offline AndyBollo
  • Country: mx
« Reply #39 on: November 30, 2017, 07:21:08 pm »
Hello!
I bought the AM-270 on Dec'2013 and it already came with the nice orange backlight.  Almost 4 year now and I still very happy with the purchase, is a very useful and good equipment. Perfect for electronics repair.  DIYers should no look further.
Offline osteichthyes
« Reply #40 on: August 15, 2018, 09:26:41 am »
I don't mean to resurrect an old thread, but I've been using one of these for about a year and I absolutely love it. I was recently offered a sweet deal on a Fluke 87 and realized that aside from its great form factor and nice feeling in the hand, it really didn't do much my 270 doesn't. And the Amprobe does a lot the (original) 87 doesn't. All that is to say, it's a heck of a meter! (I don't mean to suggest that a comparison of products made 20+ years apart is reasonable, but rather that it does a lot of things really well).
I did notice one oddity when I took it apart recently. Around the input jacks, there's a piece of plastic that runs in the slit in the board. On my AM270, the battery wire ran underneath this plastic and actually got pinched a bit. So, I took the board out and ran the wire around it. This meant the battery wires run directly on top of the 10A input jack. Which, I'm sure is fine, but it seems like a surprising design oversight. Anyone else have any thoughts about this?
« Last Edit: August 15, 2018, 09:46:13 am by osteichthyes »
