Author Topic: TE Boot up times and Boot cycles #  (Read 28561 times)
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
Re: TE Boot up times and Boot cycles #
« Reply #25 on: July 15, 2015, 03:37:52 am »
Yes; I could not find this on both Rigols above. Perhaps I am missing something, but I really could not find such count.
It will be in a Utilitiy or System menu or sub menu.
Likely also displays HW, FW, SN etc
Yep, I found the menu that displays all this info, but the number of power cycles is not there (both the 1102E and the 4014)
Offline dadler
« Reply #26 on: July 15, 2015, 04:00:10 am »
I finally found one of my pieces of equipment that has a true "boot count":
You can tell I've used it a lot, a whole 11 power cycles!
I discovered this screen when I updated the Firmware recently (thanks Franky!)
I purchased 2 off Franky.
Mine are running v2.4.
Where do I get the updated firmware?
Email him and he will send you a link and instructions.
I had to make a pogo-pin adapter on protoboard:
Offline Mr.B
« Reply #27 on: July 15, 2015, 04:06:20 am »
Thanks. Have done just that.
Offline tautechTopic starter
« Reply #28 on: July 15, 2015, 04:22:34 am »
Well, may as well join in. No power cycle counter on these.
That's very surprising, but I'd wager there is.
Maybe not accessable to the user but probably in a Service menu like the TDS Teks.
So for all the cracking and hacking of Rigols has nobody found this yet.  :scared:
« Reply #29 on: July 17, 2015, 11:03:05 am »
Shameless bump.
Siglent SHS810
16.5 seconds
Boot cycles 34
Offline miguelvp
« Reply #30 on: July 20, 2015, 03:33:37 am »
At the risk of hurting my chances to get this, I'm going to bump this thread because it's pretty awesome what Siglent is doing.
Offline GreyWoolfe
  • NW0LF
« Reply #31 on: July 20, 2015, 12:51:16 pm »
Hacked Hantek DSO1052B boot time is 13.93 sec and 54 cycles.
Offline Howardlong
« Reply #32 on: July 20, 2015, 07:36:56 pm »
I don't know how real the first one is bearing in mind the age of the scope.
Offline McBryce
« Reply #33 on: July 20, 2015, 09:24:19 pm »
I have a Tektronix 2465 (no A or B). Can I pull up that info on it too? And if so, what buttons do I need to be pressing?
McBryce.
Offline Howardlong
« Reply #34 on: July 20, 2015, 10:01:25 pm »
McBryce.
It's in appendix A of the 2465/67B manual. I'm out and about at the mo, but something along the lines of holding the delta V and delta T buttons and while holding them press trigger Slope.
Then upper and lower trigger Mode selects test or exercise.
Press Upper triggering button to execute, lower to exit.
A/B trigger button to exit.
I may have transcribed that wrongly, almost through a bottle of Cloudy Bay SB. Bad day at the office. :-)
Offline Howardlong
« Reply #35 on: July 20, 2015, 11:53:00 pm »
This much maligned scope had been my trusty steed for nearly a decade until I found eevblog. With it, I developed a number of successful products. Difficult to think it's only had 563 genuine power cycles considering its value in terms of the hardware it helped me develop over those years.
But seeing that crusty 320x240 screen just now after its months in hibernation, eugh! I may grimace now, but not half as much as I did when I bit my tongue and paid £1,800 (~$3k) for it new a decade ago.
Offline Howardlong
« Reply #36 on: July 31, 2015, 09:43:37 pm »
Recommend y'all enter this competition, I just received notification I won July's draw!
Offline miguelvp
« Reply #37 on: July 31, 2015, 09:57:00 pm »
I should have kept my mouth shut fingers tied up.
Nah, Congrats!
« Reply #38 on: July 31, 2015, 09:59:16 pm »
Really, wow.  :-+
Congrats.
What will Howard pick.....DSO or AWG
 :popcorn:
Offline GreyWoolfe
  • NW0LF
« Reply #39 on: July 31, 2015, 10:27:11 pm »
I might as well redo this with a pic to make Sigilent happy.  Boot time is still 13.93.
Online nctnico
« Reply #40 on: July 31, 2015, 10:33:08 pm »
Really, wow.  :-+
Congrats.
 :popcorn:
I strongly suggest the AWG  >:D
Offline cs.dk
« Reply #41 on: August 01, 2015, 07:08:58 am »
Rigol DS1054Z (with all options) - ~23 secs. :-+
« Last Edit: August 06, 2015, 01:52:47 pm by cs.dk »
« Reply #42 on: August 02, 2015, 10:07:23 pm »
Bump.
Howard won the July draw ^^^^^, be in to win for the August draw.
Siglent want to see boot cycles # for you to be eligible.
Come on guys and gals.
Offline Monkeh
« Reply #43 on: August 02, 2015, 10:09:01 pm »
Bump.
Guys, I mean the boot up times, not time. all right, time is also ok.
at least attach a picture.
Seeing as not all equipment has a counter..
Offline tszaboo
« Reply #44 on: August 03, 2015, 02:54:58 pm »
Congrats, Howard!
Tek TDS2014, 35 second and 224 cycles. I just put two in it...
« Reply #45 on: August 03, 2015, 10:02:18 pm »
Calling Deathwish, calling Deathwish.
Where you wanting a new AWG?
Post some screenshots and be in for the August draw.  :-+
« Last Edit: August 03, 2015, 10:37:04 pm by tautech »
Offline Deathwish
  • Country: wales
« Reply #46 on: August 03, 2015, 10:10:34 pm »
<= 5 seconds. my  dmm comes on almost instantaneously, you never specified what type of TE was valid  :scared:
In fact my digital verniers come on in less than a fraction of a second. still TE....
« Last Edit: August 03, 2015, 10:16:04 pm by Deathwish »
Electrons are typically male, always looking for any hole to get into.
trying to strangle someone who talks out of their rectal cavity will fail, they can still breath.
God hates North Wales, he has put my home address on the blacklist of all couriers with instructions to divert all parcels.
« Reply #47 on: August 03, 2015, 10:39:52 pm »
C'mon buddy get with the program.....read the OP.
Offline Deathwish
  • Country: wales
« Reply #48 on: August 03, 2015, 10:51:14 pm »
I did !.
ALL BRANDS AND TYPES of TE are invited
« Reply #49 on: August 03, 2015, 10:59:46 pm »
Then why are we waiting?  :box:
C'mon guys and gals.......
