Author Topic: Siglent 1104XE hardware update 6.1.35R2 issues  (Read 1430 times)
Offline sharktank1Topic starter
« on: June 06, 2020, 01:05:14 am »
I just did this update and it did fix a few things (Auto setup used to brick the scope). But now I've lost my impedance settings per channel and the frequency filtering per channel. Where did they go?
Offline mroek
  • Country: no
Re: Siglent 1104XE hardware update 6.1.35R2 issues
« Reply #1 on: June 11, 2020, 10:40:10 pm »
Surely you didn't do a hardware update...
I've also noticed that the impedance setting is gone in this firmware, but I guess it's because you couldn't really change the impedance anyway. It's fixed at 1 M for this scope, so having a menu item for it makes no sense. What do you mean by frequency filtering? The channel bandwidth limit (to 20 MHz) is where it used to be.
Offline Coyote
  • Country: si
« Reply #2 on: July 26, 2020, 03:59:42 pm »
Don't you think that impedance could be also 50 ohm if you use a terminator?
Offline MathWizard
« Reply #3 on: July 27, 2020, 03:43:24 am »
OP do you mean you can no longer set 1x, 2x, 5x 1Meg, etc probe imp?
And you can't choose 20MHz or full BW ?
Offline TK
« Reply #4 on: July 27, 2020, 04:10:28 am »
SDS1104X-E never had 50ohm input impedance option, only 1M
« Reply #5 on: July 27, 2020, 04:13:30 am »
No, very early SDS1*04X-E SW had a 50 ohm input selection yet the X-E models have never had the HW installed to accommodate such.
AFAIK this was a SW carryover from the earlier SDS1*02X models that share the same UI.
As it was confusing and 50 ohm inputs are not supported the option was removed from the X-E channel menu.
Offline rf-loop
« Reply #6 on: July 27, 2020, 08:26:47 am »
But, in BodePlot menu and in FFT meny there need be impedance selection and afaik there is and if user do not change default value is 50ohm. And this impedance setting mean EXTERNAL impedance (load) in scope input terminal. Impedance setting must be there and it is there. Other case it is impossible  to select power scale for vertical (usually dBm). So, all places where need be 50ohm selection there is. (there is more, user can select also of course some other values just arbitrary or mostly used standard values like 75, 120, 300, 600 ohm etc)
In SDS1x04X-E models have never been internal 50ohm (but as @tautech told in scope input menu it have been in very old FW but without any effect as residue from other model).
And when user set these values in FFT or BP settings user is responsible about impedance matching in scope end of test setup, so if your transmission line is 50ohm need add external feed tthru terminator to scope input and select 50ohm in scope settings. In SDS1104X-E there is not this setting in normal xt scope setup menu. But there is also not power scale. This setting is with operating modes where user can also select power scale instead of voltage (or current). In this scope BP and FFT.
« Last Edit: July 27, 2020, 08:38:41 am by rf-loop »
EV of course. Cars with smoke exhaust pipes - go to museum. In Finland quite all electric power is made using nuclear, wind, solar and water.
