Author Topic: TDS754D Fail +++ Processor.  (Read 8643 times)
Offline charlydTopic starter
Re: TDS754D Fail +++ Processor.
« Reply #25 on: November 04, 2017, 09:15:14 am »
and again a new update -> the Eeprom arrived... the FATAL: 250 NVstorage too small more bytes requested then available -> is gone fixed!
now i only have this ERROR: Diagnostic test failure nvlibrarianDiags, libs with crcc failures: , ExtConst
still FAIL +++ CPU/DRAM Processor +++  i assume a matter of calibrating?
Offline cherrylee
  • Country: cn
« Reply #26 on: July 10, 2018, 03:09:49 am »
My oscilloscope has the same problem as yours.
I replaced X24C02 with AT24C02 ,but the problem remains.I can't read its data and back it up
My oscilloscope is TDS784D.
Can you give me some help?
Offline maaii
  • Country: tw
« Reply #27 on: July 10, 2018, 10:12:37 am »
Hi
I think you should use the backup 24c02 of Jwalling post
« Reply #28 on: July 12, 2018, 05:00:39 pm »
 hi send me a pm with your email adress so i sent you the files
« Last Edit: July 12, 2018, 05:15:31 pm by charlyd »
Offline cherrylee
  • Country: cn
« Reply #29 on: July 13, 2018, 03:25:46 am »
OK
I have sent you a message, thank you.
« Reply #30 on: January 13, 2020, 12:50:37 pm »
here is the result of my Scope.. as asked in an other topic working 100% and one of the options is 2M.
the clue was place both 24C02 on the board empty don t programm/flash them with sh*t from other scopes....just take your FAS and recalibrate the unit and it is going to work.
tek firmwarelist: difference in versions depends on board versions.(serials at the backside B0xxxxx)
TDS310, F/W,2.04
TDS320, F/W,2.04
TDS340, F/W,1.09
TDS340A,F/W,1.09
TDS350, F/W,2.04
TDS360, F/W,1.09
TDS380, F/W,1.09
TDS410, F/W,2.53
TDS410A,F/W,1.02
TDS420, F/W,2.55
TDS420 ,F/W,2.60
TDS420A,F/W,1.02
TDS430A,F/W,1.02
TDS460, F/W,2.55
TDS460, F/W,2.60
TDS460A,F/W,1.02
TDS510A,F/W,1.00
TDS520, F/W,2.16
TDS520A,F/W,3.87
TDS520B,F/W,4.21
TDS520C,F/W,5.3
TDS520D,F/W,6.3
TDS520D,F/W,7.11
TDS524A,F/W,3.87
TDS540, F/W,2.16
TDS540A,F/W,3.84
TDS540B,F/W,4.21
TDS540C,F/W,5.3
TDS540D,F/W,6.6
TDS540D,F/W,7.11
TDS544A,F/W,3.84
TDS580C,F/W,5.3
TDS580D,F/W,6.3
TDS580D,F/W,7.11
TDS620, F/W,2.06
TDS620A,F/W,3.87
TDS620B,F/W,4.41
TDS640, F/W,2.06
TDS640A,F/W,3.88
TDS684B,F/W,4.41
TDS680B,F/W,4.41
TDS644A,F/W,3.85
TDS644B,F/W,4.41
TDS714L,F/W,6.6
TDS714L,F/W,7.11
TDS724A,F/W,4.21
TDS724C,F/W,5.3
TDS754C,F/W,5.3
TDS724D,F/W,6.3
TDS724D,F/W,7.4e
TDS744A,F/W,4.21
TDS754A,F/W,4.21
TDS754C,F/W,5.11
TDS754D,F/W,6.6
TDS754D,F/W,7.4e
TDS782A,F/W,4.21
TDS784A,F/W,4.21
TDS784C,F/W,5.3
TDS784D,F/W,6.6
TDS784D,F/W,7.4e
TDS794D,F/W,6.6
TDS794D,F/W,7.4e
TDS820. F/W,2.03
TLS216, F/W,1.03
THS720, F/W,1.03
THS720A,F/W,1.16
THS710A,F/W,1.16
THS720P,F/W,1.16
THS730A,F/W,1.16
« Last Edit: January 13, 2020, 09:20:14 pm by charlyd »
