Did you see any beam without a input signal?
Yes. If I configure it as you say, with the "Mode" on A or ALT (but not B), I can get one line at a time with CH1, BOTH or CH2 in the Vertical switch. I can't seem to get both flat line simultaneously no matter what I do. Channel 1 is a nice fine line. Channel 2 is a noisy line. On "Both" the line looked like the Channel 2 line.
As I was playing with this, though, I eventually stopped being able to get a horizontal beam on Channel 2. Beam finder shows it's in the lower left quadrant but no display.
How did you connect your function generator to the scope?
Connected the Rigol probe to the oscilloscope. Connected the function generator's BNC to alligator clip to the Rigol probe, red on the tip and black on the ground alligator clip. I have a straight through BNC cable but didn't try it.
The same configuration worked on the Rigol scope.
I'll try that googling. Maybe I should just open it up and see if anything visually obvious sticks out at me.
Edit: I found the referenced document. Quite a treatise. I will have to work my way through it. I thought maybe opening it up and cleaning it liberally with contact cleaner might be a good first step. The scope came from a smoker's home (which was very evident by the smell).
Are you sure the FG is working?
Yes - it was tested before and after with the low-end Rigol.
Thanks,
Doug
