Looking for help with a wiring diagram for 4 different Sencore probes, for 2 different pieces of Sencore test equipment.
First one is a Sencore VC93 all format VCR analyzer, need wiring diagrams for
1. Performance Test Lead, part number 39G235
2. Servo Troubleshooting Test Lead, part number 39G236
The front of the VC93 has one female plug for these 2 test probes, can only plug in one probe at a time. The plug has 5 inputs and a ground. Each test lead uses 2 inputs and ground. Therefore, there may be a left over, unused input on the front of the machine. Have studied the schematics, and the labels do not adequately provide enough information to unravel the mystery of how these two test probes are wired.
Second test equipment is Sencore TVA92 TV Video Analyzer, need wiring diagrams for
1. Ringer/Load Test Leads, part number 39G298
2. Dynamic Test Leads, part number 39G299
Any help, especially with the VC93 probes would be very appreciated. Plan to use this equipment to maintain VCR’s for archiving video tapes.
