Hi!
I hope it hasnt already been discussed but im having an issue with my TDS5104. The scope works as supposed and has one external VGA port which also works as it should.
The issue is that when i set up the external screen using parameters similar to the internal screen and set the external as the primary in the operating system the scope program executes as it is supposed to, its running and can be operated but will not show the traces.
Is there any way to fix this?
best regards
