This posts continue my TDS540 repair adventure and sega
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
Now the scope is turning on but now every time it fails acquisition and sometime acq/processor interface (when the scope is working for a whil it don't fail).
It show waveform to all of the channel but there is some imperfaction. I show those in one picture.
I will post the image regarding the error I get in the log. Every time it fails the signal path test.
For what I can figure out, There is memory curraption.
Despite that, anyone know which memory chip we could use to replace the current acq memory?
And anyone have a memory map for the TDS540.
I have understood that the memory error refer to channel 4(adress 0x73xxx) but what chips give the two error (adresses 0x73c0046 and 0x79c00c6)?
And this errors means:
- Insufficient differential response DigA gain cal,
- Call means clipped at max dig output , Ch2 balance call of attenuator
- Calibration failed trigger (ERROR 2260)
Anyone can help me to figurate what is not working?
This is the link for the images:
https://dl.dropboxusercontent.com/u/89622982/TDS540%20Images.zip
