Hey BTO, thanks for the quick responce. No luck, still didn't work.
Hardware version: 1.01.000. If that is of any use.
Here is a bit of a checklist
don't just skip through this and say yeah yeah... Actually confirm each step, ok
- When you installed Python did you do a CUSTOM INSTALLATION ?
- Did you also check the box that says PATH ?
- then after installing python, did you open cmd.exe or powershell and typed in
python
then press ENTER to get the compiler screen,
Did you successfully get the screen ?
You can then type
exit()
and ENTER to get out of it
- did you connect your scope to your PC Correctly and with Non Faulty Cables ?
- did you go into the scopes LAN settings and confirm DHCP is on and that the I.P. Address range, Matches the I.P. Address range in your router
when you open cmd.exe and type in
ipconfig
then ENTER
- then... Open cmd.exe or Powershell, (whichever you like) DID YOU NOTE THE WORKING DIRECTORY ?
Meaning if you open it and the path is
C:\Users\User
Did you place the script in that location ? IF NOT.......... DO THAT !
- then when you created the regen file
-- was there another regen file or script in that location ? if there was.. DELETE IT !
both the script and the regen file need to be in the same location as the working directory path that shows up in Python.
You must also use ONLY
cmd.exe OR
Powershell
Do not use the Python CLI that comes with the installation.
- After that , You are supposed to ensure that you remove the patch method, this is done by dropping from version 1.3.3.0 to 1.3.2.2 (you've done this)
- it's then just a question of
Load the -i command
Load the -r command
Load the script without any switch
then shutdown and reinstall 1.3.2.2
then restart and again
Load the -i command
DO NOT DO THE -r again
then load the script without any switch again
At this point it will activate
You seem to be falling over at the regen priv.pem stage
Check the folder locations
and also when redoing all this, i would use the first script again not the _3_000.py one
Let me know if you want to jump on zoom
I'm off to bed now
