Author Topic: Fuses for the Triplett MM525(UNI-T UT139S)  (Read 240 times)
Offline ClifSTopic starter
« on: Yesterday at 01:44:31 am »
I just received the MM525 (UNI-T UT139S) a couple of days ago as a backup meter. In all respects it seems to suit my purposes. However, before doing much with it, I decided to order some spare fuses, which are the FF 600mA H 600v 6x32mm and the 10A H 600v 6x25mm. First one is common as dirt, but that 6x25mm 10A seems to be a rare bird. Word from Triplett is "you can find them anywhere on Amazon or Ebay". Not.
Any thoughts on where i might source these? Otherwise the DMM is going back.
Thanks for your help.
Clif
Offline 44kgk1lkf6u
Re: Fuses for the Triplett MM525(UNI-T UT139S)
« Reply #1 on: Yesterday at 03:09:14 am »
A quick search only gave me this one listing on Ebay for $21.74.
https://www.ebay.com/itm/395361050818
McMaster-Carr only lists 8AG size fuses with a 250V voltage rating.  But it says, "Don't see the fuse you need?  Just tell us what you're looking for and we'll get it for you."  I would be interested in seeing what they can find.
Offline myf
« Reply #2 on: Yesterday at 05:27:39 pm »
I also found this fuse with the main properties : 5x : 6mm x 32mm, FF10A 10A 600V
https://fr.aliexpress.com/item/664820789.html
Offline stj
« Reply #3 on: Today at 01:40:59 am »
if the pcb lets you move the clips then use a 32mm fuse,
otherwise the 25mm fuse is a standard u.k. plug fuse that is *very* cheap, but it's not FF type speed
https://uk.rs-online.com/web/p/cartridge-fuses/0412598
notice the maker is American - so you should be able to find a distributor
« Reply #4 on: Today at 01:02:34 pm »
Thanks all. :D
