Author Topic: Tablet Oscilloscope-tbook, a new kind DSO.  (Read 104188 times)
Offline MicsigTopic starter
« on: October 24, 2013, 02:51:49 am »
hello, here i would like to introduce a new kind DSO to you. Tablet Oscilloscope-tbook series.
first, see the appearence.  10.1 inches, full touch. no knobs and button. 4 channels.
« Last Edit: November 01, 2013, 01:11:00 am by Micsig »
Offline Stonent
Re: Tablet Oscilloscope-tbook, a new kind DSO.
« Reply #1 on: October 24, 2013, 02:55:30 am »
I don't see it going over well. People want knobs. Also you gave no specs.
Does it have wifi? Does it have a full OS like Windows 7/8, mini OS like RT or CE, Linux, custom?
Offline Bored@Work
« Reply #2 on: October 24, 2013, 02:58:19 am »
To make this absolutely clear:
Fuck, no. No knobs, no sale.
And really, how is this different from all the DSO Nano junk people try pushing to inexperienced beginners?
« Reply #3 on: October 24, 2013, 03:02:31 am »
Key features:
 :)Select from 70MHZ,100MHz,150MHz,200MHz,300MHz,350MHz,500MHz,600MHz,1GHz bandwidth models
 ;)1GSa/s to5GSa / S real time sampling rate;
 :D200,000wfms/s max waveform capture rate
 ;D 18 to 360Mpts memory depth
?::)Support multi-language, adjust the viewing mode with different brightness Automatically
part of optional SW
?   support UART, LIN, CAN, SPI, I2C, I2S, 1553B, and 429 serial bus triggering and decoding
?   Support WIFI, LAN, USB2.0 connectivity and HD video analysis
?   Integration of 5 ½ and 6 ½ high-precision multimeter, recorder and function waveform generator.
« Last Edit: November 01, 2013, 01:11:40 am by Micsig »
Offline cloudscapes
« Reply #4 on: October 24, 2013, 03:06:05 am »
Knobs and buttons are really needed.
Offline cloudscapes
« Reply #5 on: October 24, 2013, 03:08:29 am »
How 'bout a video of someone using it so we can see waveform update and general usability?
Offline BravoV
  • +++ ATH1
« Reply #6 on: October 24, 2013, 03:09:37 am »
Select from 70MHZ,100MHz,150MHz,200MHz,300MHz,350MHz,500MHz,600MHz,1GMHz. bandwidth models
But ..but ... its capable of an impressive 1 Ginga Munga Hurtz ...  :-DD   :palm:
Offline pickle9000
« Reply #7 on: October 24, 2013, 03:09:46 am »
Does it have an external trigger?
Starting price?
Offline pickle9000
« Reply #8 on: October 24, 2013, 03:20:35 am »
It's a portable or rather a large handheld (battery and optional isolated inputs), I guess it depends on how you look at it but few if any handhelds have knobs. Like everything it's a wait and see.
http://www.micsig.com/Pro_View.asp?News_ID=29
Offline rolycat
« Reply #9 on: October 24, 2013, 03:21:10 am »
As well as the "1GMHz" it boasts "up to" 5GSa/s, 200,000wfms/s and 360Mpts memory depth. Oh, and an integrated 6 1/2 digit multimeter and a waveform generator.
http://micsig.gmc.globalmarket.com/products/details/micsig-tablet-oscilloscope-tbook-series-to72-70m-2-channels-3355852.html
All of these world-class specifications are repeated three times on the page, so they must be true...
Offline c4757p
  • adieu
« Reply #10 on: October 24, 2013, 03:50:27 am »
That's quite the little thing. I don't see fitting much internal shielding in there. So... your specs look decent, if they're true, but quote me this one: noise floor. How much of its own clock and power crap gets picked up? I want to be able to look at a signal at 10mV/div without having to guess how much of what I see is actually coming up the probe cable.
This was my first thought as well. But once in a while, touchscreen is done right. Can you do it right? I don't just want LCD buttons to smear my fingers on, I want an intuitive touch interface with proper tactile manipulation of the data. Show it in use!
Also... can a few heavy, thick cables plugged into it knock it down? There is definitely an advantage to equipment filled with bricks...
« Last Edit: October 24, 2013, 04:06:32 am by c4757p »
Offline Stonent
« Reply #11 on: October 24, 2013, 04:17:18 am »
Very original.
Offline EEVblog
« Reply #12 on: October 24, 2013, 04:21:35 am »
BTW, Micsig are not spamming the forum, they have permission to post here.
The form factor aside, the specs seem very impressive for a new company.
I do wonder where they get their 1GHz front end from, and 300K/wfmssec, I'm mean, that sort of bandwidth and speed doesn't just pop out of nowhere from scratch from a new company.
Offline EEVblog
« Reply #13 on: October 24, 2013, 04:23:02 am »
Yes. How long would this puppy last in a typical lab before going walkabout and tucked away in someones draw...
Offline EEVblog
« Reply #14 on: October 24, 2013, 04:26:09 am »
As for knobs, well, I don't know of any hand held scope on the market that has knobs?
Offline BravoV
  • +++ ATH1
« Reply #15 on: October 24, 2013, 04:26:21 am »
Isn't that in 1 GHz range, the BNC is simply not the right connector anymore ?  :-//
Unless its a "GMHz", then I don't have any clue at all.  :-DD
Offline mtdoc
« Reply #16 on: October 24, 2013, 04:26:38 am »
You found EEVBlog - good first step.
Now - if you want to sell some of these the next step is to send one to Dave for a proper review..
Offline EEVblog
« Reply #17 on: October 24, 2013, 04:27:44 am »
With 4 channels you don't need external trigger.
Offline c4757p
  • adieu
« Reply #18 on: October 24, 2013, 04:30:47 am »
Little gadgets like this? Nah.... send 'em to Mike Harrison. >:D
Offline EEVblog
« Reply #19 on: October 24, 2013, 04:36:11 am »
Offline pickle9000
« Reply #20 on: October 24, 2013, 04:49:51 am »
They have a whole range 2-4 channels and various bandwidths
« Reply #21 on: October 24, 2013, 05:40:24 am »
we are making it, but it will take some time. thanks.
« Reply #22 on: October 24, 2013, 05:42:36 am »
several years ago, we used the button cell phone, but now we are using the touch cell phone.  ;D ;D
which is eaiser and more convenient, and you will choose.
« Reply #23 on: October 24, 2013, 05:44:01 am »
   |O |O |O i have to say, i am stuip and lazy, but i will change... :-[ :-[
Offline Bored@Work
« Reply #24 on: October 24, 2013, 05:53:07 am »
That's why I don't want handheld scopes. But this one can't even be hand-held properly.
It is a 60 mm thick 10" tablet, weighting 1.8 kg. Just some kind of grove on the top back side, no grip, and the probe cables going out to the left.
So if you are a right hander you can't just hold that thing in your left hand and keep fondling it with your right hand. If you change hands, you'll quickly get tired holding that 60 mm brick in your right hand and touching with the left. You can't hold it in both hands and try to touch-operate it with your thumbs, unless you have super large thumbs.
So you have to have it lying flat or standing on its tilt. This thing is at best portable.
And while we are at it:
CAT rating? Independently verified?
