I would like to ask about the differences from the R&S RT-ZM modular probe system to the normal active probes (single ended/differential).
The RT-ZM probes can switch between single-ended, differential and common mode.
So if i understand that correctly it basically can do all the measurements with just one probe.
The only differences i could find with my basic understanding and short research are the dynamic range and DC input resistant.
Im just curious, in what scenario would you use the single ended or differential active probe over the modular system?
So my real question is, which scenarios are not working for the modular system?
At my work we are currently deciding if we want to purchase the R&S MXO4 as a good common use oscilloscope and which accessories we should buy.
So i was thinking the best option for the most scenarios would be the modular system.
Im not that familiar with high end measurement equipment, so please excuse me if im clearly overlooking something here.
