Thanks!
That's -exactly- what I needed. I even took time to RTFM and still missed that option.
But....if you Default the scope you will need to reset it.
I like it set 2 div from left to see pretrigger info.
Still there is a further option to make Fixed H Pos a Default setting.
Start with Default to factory.
Adjust to preferred settings for
everything.....takes a minute or 2.
Save/Recall> Save> Type> To Default Key> Current Setup or Factory Setup (Default)
You can do similar in Save> Setup, 10 types can be saved and Recalled from internal memory and an unlimited # to external memory.
They just take a little more effort to recall than pressing a previously set up
user Default.
