Author Topic: Stunning 3000A, 2000A, 3000T power supply discovery - MUST READ IF YOU HAVE ONE  (Read 19163 times)
Online EE-diggerTopic starter
Reply #53 in this thread may be of interest to you:  https://www.eevblog.com/forum/repair/dso-x-3024a-power-supply-defect/50/
At 400k+ ohms, the startup voltage was 135 volts.  Perhaps not an issue for you but would be on 120v mains.
« Last Edit: February 08, 2024, 01:47:43 am by EE-digger »
Another happy camper with a Murata PQC250-12 installed.
It took a few resistor moves to invert the remote on/off signal and it took a bit more doing to get rid of very annoying acoustic noise whether on or off.
Spoke with Murata and one of the posters and no one has had this problem.  I had it on the two supplies I tried.
It comes down mostly to one capacitor (ceramic, 10uF) that sounds like a dentist drill if you gently touch the top with tweezers.  My solution was to replace it with a Murata metal mounted cap of same value.  You can also get interposer caps.  I first made my own interposer before the Muratas arrived by simply mounting the cap piggyback on a 1 Mohm 1206 resistor.  I have to say that this was quite good.
If anyone want the on/off inversion info, I'll post it.
Offline Helix70
  • VK4JNA
Yes please, my MSOX3014T (early model) power supply just died (GE CCH0125F1-Z03A) and am researching the best replacement options. Having the correct switch position is important to me as it is a work scope and I don't want the risk assessment!
Offline djsb
I have a Keysight MSO-X3054A. Is this scope affected by this and what should i be looking to replace in the power supply and with what? Thanks.
Hertfordshire, UK
University Electronics Technician, London, PIC16/18, CCS PCM C, Arduino UNO, NANO,ESP32, KiCad V8+, Altium Designer 21.4.1, Alibre Design Expert 28 & FreeCAD beginner. LPKF S103,S62 PCB router Operator, Electronics instructor. Credited KiCad French to English translator
