are you looking for any specific performance metric? I checked the linearity across the frequency range, and it seems to be good. Jitter I measured and got it worse than I expected but I am not too sure whether it is coming from my oscilloscope or it is coming from the generator. I need to get a good 50 Ohm terminator before I can conclusively say the amplitude linearity is good. I don't know how the higher frequency ones perform, they might have a different circuit in them. The seller i bought from was only selling a 15MHz and 30MHz if the sample rate isn't higher for the 80MHz then the arbitrary waveform frequency and square wave frequency will still be limited to the same level as the 15/30MHz models
The thing I don't like is the user interface, it just not what I would expect, it looks really good but I feel like they just looked at images and copied the design. Now I have never owned such a LCD interface function generator before so I can't say it is better on other models.
for example, if i want to choose an arbitrary waveform I can't preview it, i can only read the name and press on it. It will enable the waveform and since there are 100+ built in and some like Voice which you have to see before you choose it is bad. Then things like the sweep function, if it is sweeping you can't see what frequency it is at it will just sweep with a static display, when you want to change parameters of the waveform like amplitude you have to press a button but then in that screen it does not show a frequency sweep it just shows a regular waveform with a fixed frequency. Such small things here and there make me feel like they just looked at images and made the interface. I might be ranting a lot about the user interface, it's because the hardware is good, and the interface looks good, i am just disappointed at the execution. Things like that matter a lot to me, but it might not matter a lot to many
ranting about the interface, i should mention the colours on the display are very unsaturated and the multifunction knob is mushy and the indents while rotating don't feel good
