Author Topic: How old is my Triplett 310?  (Read 175 times)
Offline BeBuLamarTopic starter
« on: Today at 12:35:38 am »
I just bought this Triplett 310 VOM today at an estate sales for $7.50. It's full functioning and reasonably accurate. It reads a bit low on both AC and DC voltages. I wonder if there is a pot for calibration? Also how old is it? I know the first one was made in 1955 and they still make them today.
Offline coppercone2
Re: How old is my Triplett 310?
« Reply #1 on: Today at 12:39:10 am »
well I got one of those from the 80's but I destroyed the acrylic knob. I have been meaning to polish out a groove in there so I can glue on something, or to find a replacement.
Check for leakage from the 12V battery in there for Ohmmeter mode.
And its adjusted by replacing resistors IIRC. That thing is pretty stable and small, I don't think I saw any trimmers in mine (but its for Bell)
Yours has a knob on the bottom, mine has more of a watch dial.
I think I have a 318 though. Maybe you can just get parts for that still, I never looked. I had a fun time polishing it with tooth paste lol
It has a potentiometer for ohms, but I don't think you can do anything with the voltage dividers other then replacing resistors
https://www.parts-express.com/pedocs/manuals/391-040-triplett-310-manual.pdf
« Last Edit: Today at 12:46:28 am by coppercone2 »
Offline coromonadalix
« Reply #2 on: Today at 01:29:33 am »
your needle mechanical zero  seems wrong for a start
and if this attached file     schematic / brochure is right you  have only 1  trimpot in it ....
and it has an 1977  stamp  on it   it give some insight ...
« Last Edit: Today at 01:33:47 am by coromonadalix »
Offline Shock
« Reply #3 on: Today at 01:59:23 am »
By the look of it 70s or early 80s is about right.
Edit:
If they didn't update the model at all looking inside will give you a rough date code if you can find a dated component or age them. Don't always jump straight to calibration to fix things. If it has a sticky or problematic movement, non zeroed or a drifted component, you will have just wasted your time and possibly made it harder to pinpoint.
« Last Edit: Today at 02:08:09 am by Shock »
Offline schmitt trigger
  • Country: mx
« Reply #4 on: Today at 04:28:50 am »
Does it read low on ALL of the AC and DC ranges?
If so…I would like to think that then it is possible that the movement itself has a flaw.
Keep us posted on what you find.
