sorry about the necrohumping, but would love an update from OP and what he ended up with..
AS I been in the same situation this last ½ year, and ended up with 3 devices for semi-based RF explorer purpose.
a 24USD PC based variant aka those cheap 31mhz to 4.4ghz variants with as I recall dual ADF4351 chips (sadly the MicroUSB port is lifted, likely from not having it in a case, so waiting for some MicroUSBsockets and will try exchange the socket) but until that happened it worked great when you have the price-paid in mine, though the software will be vital.(I got a few favorites).
and also got one of those 21mhz to 6.2ghz that I recall are using MAXIM chips (2870E)
.. and it had way better sensitivity from my rookie perspective, then the 24USD variant, but also way more expensive and around the 100dollar mark.
The cheap one on the left, and the more expensive one on the right.
but the last few weeks, been having one of these HackRF+Portapack 3.2" (v3.3)
the silver metal one
it was around 150USD (clone) though incl. 5 antennas and LIPO battery, it was preinstalled with Mayhem 1.2 and just needed assembly.
so-far I'm very impressed with this SDR and some of the SDR freeware software for these SDRs are extremely polished when using it in HackRF mode on PC (even on windows OS).
Here a brief video-look on an call with my mobile.
and here FPV AIO cam.
The signal generator on the SDR is valid for at least 6.2GHz.. I can't validate any higher than that, though the effect obviously varies across the RF span.
The menu will take input up to 7.25GHz, but don't have any spectrum-explorer tools to validate above 6.2GHz, but the +7GHz mostly in theory and to see if HackRF vendor at Def-con2014 claims hold water..
https://youtu.be/4Lgdtr7ylNY?t=1104What product did you end up with topic-starter?
