I give up...
sorry i keep missing your post, because whenever you post, i only see "show the post" for some reason... and some posters like to post pedantic stuffs creating distractions.
why give up? the challenge its not so hard, but it will reveals what i want to explain that some of you people very hard to comprehend. this is only basic stuff i dont claim i have phd...
why give up? because what you'll find is a fact that i already explained here?
https://www.eevblog.com/forum/testgear/split-from-rigols-new-dho800-oscilloscope-unbox-amp-teardown/msg5140329/#msg5140329now if you still dont get what i want to prove? 1st i already explained in 1st post and various places here (i have to keep repeating again and again) this is for awareness... if you admit the facts i was presenting, simply admit it or simply do not reply (
admission by silence) otherwise, present proofs to prove my points are wrong, in maturely and wisely and most relevant manner. forum is for healthy debate to avoid misinformations in scientific, technical community alike.
now since you (and others) dont want to take the task, may i turn to tautech, to do it for me? i need to ask favor again. because so far, he is the one the most transparent on this... and also since he stated earlier this interpolated data and stuffs are BS... here mr tautech...
https://www.eevblog.com/forum/testgear/split-from-rigols-new-dho800-oscilloscope-unbox-amp-teardown/msg5140950/#msg5140950here what i suggested for you to do earlier.... check my challenge posts earlier. dial back to where you got the gibbs effect like in this picture you showed here...
[img]
screen capture it again to show the gibbs effect as reference... and then.... this is the most important part you need to get right.... change your scope to Sinc OFF, dot mode ON, and single trigger it, until it triggered and stopped. so we can see few points on screen paused, not overlapping around. and do the 2nd capture, and post here again for comparison and analysis... cheers.
here an example of the 2nd capture i need, like tautech have made... (i would love to see same time scale as the one you got the gibbs effect above 200ns/div)
[img]i was asking it here earlier but maybe not clear enough...
https://www.eevblog.com/forum/testgear/split-from-rigols-new-dho800-oscilloscope-unbox-amp-teardown/msg5139081/#msg5139081anyone? not just tautech and 2N3055..
btw: when we try to make a claim or swear about this device not being good enough, not accurate enough, make sure we have good background knowledge to back it up, otherwise people of knowledge can easily see what is wrong with your claim and continuos attempt at spreading misinformations to people who just got into the arena. swearing about others without good knowledge is an
INSULT, to the designer and brand, and to the users too... and not trying to defend your point in maturely and calmly manner is
RUDE at least thats the culture around here (my place, not this forum)... imho.
