Author Topic: Synchronize keithley 2410 sweep with external ARB  (Read 1291 times)
Offline qwaarjetTopic starter
  • Use your imagination and pretend its linear.
« on: March 10, 2015, 08:50:16 pm »
I want want to trigger  a sweep on a kiethely 2410 with a function generator/ NI DAQ. Is there a way to do  hardware triggering for this?
Offline McBryce
Re: Synchronize keithley 2410 sweep with external ARB
« Reply #1 on: March 10, 2015, 10:28:36 pm »
Does your 2410 have the triggerlink socket on the back? It's an 8pin Mini-DIN between the RS232 and the power socket. If so, that has trigger input/output if you have or build yourself the right cable. All the info you need should be in the manual.
McBryce.
« Last Edit: March 11, 2015, 01:11:01 pm by McBryce »
