The program was not written for TCP. I wrote it for USB control. I have not tried to connect my unit via the network port.
Does the top box fill in if you click the Find and Connect button?
OK. No the Find and Connect button didn't work. I typed in TCPIP0::192.168.xxx.yyy::INSTR and then clicked the buttons.
As I use EMCview for a lot of my measurements, I don't often need a screen grabber but it might be useful occasionally.
The save file has better clarity then the image shown in the program.
I added a option button to switch between USB and TCP, then added the code behind it... If the TCP port is open selecting USB will Close it.
Start the program:
For USB Click the Find and Connect, the USB address should fill in the top text Box, click the Grab Screen Image button
Select TCP Set the IP the Subnet does nothing Leave the ports alone(Unless you have changed them) Click OK to use the IP and Ports.
Click the Find and Connect to Open the Port ( an *IDN? is sent) then click the Grab Screen Image button.
There is no save for the IP so it will need to be set when the program is re-started.
A number (file size) will show up in the text box next to the Read button, if the image does not appear I will need that number to correct the program.
For the RSA I know it's "1843254".
Please let me know if this works on a DSA815, as I mentioned I only have the RSA5065 near me to try.
