Hello, I have an DSA815TG:, mainboard: 00.04, radioFPGA: 00.05, digitalboardFPGA: 00.04, firmware: 00.01.09, . . . . I will hightly apreciate any help, Thank you very much in advance, Toño,
Hello Tono:
1. Go here to get the Rigol Keygen:
http://gotroot.ca/rigol/riglol-103d/2. Go here to get DSA800 firmware 00.01.07: You are going to Down Grade to this.
http://gotroot.ca/rigol/DSA800_FW_00.01.07.zip3. Go here to see what to do:
https://www.eevblog.com/forum/testgear/rigol-dsa-815-tg-upgrade-hack/msg2789438/#msg2789438Follow the Instructions I gave to VE7XDT for doing this:
Down Grade your DSA800 Firmware (FW) to 00.01.07 as I instructed here.
Do NOT install the Keygen Option License Code for !0 Hz RBW.
Do NOT install the Keygen Option License Code for Tracking Generator.
Install VSWR, EMI, and AMK Option License Codes.
3. After you have completed installation of the Options, verify that they are in your DSA800, and that your unit works Ok.
4. Install the latest FW available here: Don't Worry it Will Work Fine on your DSA800. Rigol's info that it won't is WRONG. You will now have 10Hz RBW, VSWR, EMI, and AMK Official Options.
https://beyondmeasure.rigoltech.com/acton/formfd/1579/0025:d-000f/If you have a problem downloading this FW send me a email address via a EEVblog PM (Personal Message) you have that allows attachments.
Note - EEVblog PM's DO NOT support Attachments!
If you have questions please ask me. Ted
Edit: When you upgrade your FW to the latest use Rigol's FW Installation Procedure
(it comes with the FW when you download it). Do Not use the one I supplied for doing the FW Downgrade back to 00.01.07. By the way even if your Options had timed out, I believe that this procedure would re-install them as Official.Edit 11/20/2019:I'm very sorry, I didn't notice before that you had Boot Loader .04. (Generally with the Hardware you have, Boot Loader .02 or .03 is incorporated). Sorry you won't be able to go back to FW .07, and your only choice is to solder Pins 7 and 8 of IC U1105 together (this should work fine). Although you could install a secure/hidden toggle switch, but be WARNED! - Never change the switch's from OFF-ON or ON-OFF when the DSA800 is ON (turn the DSA800 'OFF' first). The Data in U1105 can potentially get corrupted and you loose all the calibration data.
