Hello everyone,
First of all, let me thank you all for all the precious informations shared in this topic. I will try to do my part now, as much as possible from me. I just finished reading all 35 pages of posts in this topic and I must say that I learned a lot. Thank you all!
Now, I own one DSA815-TG since February and so far, I am happy with it; although, I have not given it much use until recently.
Right now, my SA has the latest firmware available (1.18) as shown below. Also, this SA hasn't been hacked, opened or modified.
![](http://www.airlomba.net/ADB/imagens/eevblog/1.jpg)
One thing I read in some topics (page 22), is about the "missing steps" in the power sweep. So, I tried to replicate this function and I think the thing has been solved as you may see in the picture below:
![](http://www.airlomba.net/ADB/imagens/eevblog/7.jpg)
If anyone would like me to do some experiments, please feel free to ask. Also I need the experiment procedure detailed so I can do exactly what you want (as long as it doesn't imply to open the instrument).
Now for the down side of updating my SA to the latest firmware version. Before the update I had firmware version 1.12 and about 23 hours of trials left. The update process went smoothly without a problem, except that, at the end, my trial timers were set to ZERO. I contacted the SA vendor (in Europe) and they provided me some new trial licenses for some of the options I still wanted to try. I installed the licenses as per normal procedures, they got installed, but the option aren't active, as one can see in the following screenshots. The final result is that I have the trial timers with 36 hours but the options inactive...
![Banging Head |O](https://www.eevblog.com/forum/Smileys/default/bangheadonwall.gif)
![](http://www.airlomba.net/ADB/imagens/eevblog/3.jpg)
![](http://www.airlomba.net/ADB/imagens/eevblog/2.jpg)
![](http://www.airlomba.net/ADB/imagens/eevblog/8.jpg)
Contacted the vendor again (as a pivot to reach Rigol) and the answer was that Rigol said that there may be some incompatibility between the hardware and the new trial licenses... I will try to contact directly Rigol Europe or whatever to try to solve this issue. Any feed back I have, I'll post here just in case it may be useful to someone.
Best regards to all,
Emmanuel.
