Author Topic: SPD3303X-E  (Read 1183 times)
Offline BillyOTopic starter
SPD3303X-E
« on: April 28, 2023, 02:31:08 am »
There does not seem to be a general thread on these power supplies, so I thought I'd start one with a generic enough title to serve as such.
That said, I do have a question.
I know you can series the two main supplies in this unit to get 64V.  My question is, can you then manually series the auxiliary supply to get a total of 69V @ 3.2A?
Want to see an old guy fumble around re-learning a career left 40 years ago?  Well, look no further .. https://www.youtube.com/@uni-byte
Offline modoran
Re: SPD3303X-E
« Reply #1 on: April 28, 2023, 07:44:31 am »
No, the 3rd channel is not galvanically isolated, it is derived from the 2nd channel.
Offline Performa01
  • Country: at
Re: SPD3303X-E
« Reply #2 on: April 28, 2023, 08:50:10 am »
You seem to confuse this with Rigol or something.
On the Siglent SPD3303X/X-E, all three power sources are independent and galvanically isolated.
So the final answer is: yes, we can!
Offline tautech
Re: SPD3303X-E
« Reply #3 on: April 28, 2023, 10:12:42 am »
And with a fresh reply from Siglent this picture is proof, admittedly it is a SPD3303C with wired series connections however it clearly shows the 3rd channel with a 5V setting used in the series chain.
Offline alm
Re: SPD3303X-E
« Reply #4 on: April 28, 2023, 10:45:26 am »
Indeed, Rigol has a fully adjustable third channel that's not isolated from channel 2, while Siglent has an extremely limited third channel that's fully isolated.
Offline tautech
Re: SPD3303X-E
« Reply #5 on: April 28, 2023, 10:53:10 am »
Yet, multiple SPD3000X/X-E models can be series'ed together to a max of 500V above mains ground.
Done it myself to 120VDC after confirmation from Siglent it is an design feature and accepted practice.
Offline daisizhou
  • Country: cn
Re: SPD3303X-E
« Reply #6 on: April 28, 2023, 12:52:22 pm »
https://youtube.com/shorts/0mKmwa-MJRo?feature=share
Do you know how to adjust my SPD3303D?Especially the voltage of CH1 channel
daisizhou#sina.com #=@
Re: SPD3303X-E
« Reply #7 on: April 28, 2023, 03:46:44 pm »
I'm sold.  Just put in my order.  :-+
Re: SPD3303X-E
« Reply #8 on: May 01, 2023, 02:53:39 pm »
Look what just came in the door, like, 5 minutes ago:
Re: SPD3303X-E
« Reply #9 on: May 01, 2023, 03:14:31 pm »
And now a few minutes later ...
Re: SPD3303X-E
« Reply #10 on: May 01, 2023, 04:12:50 pm »
Hmmm,
Is there a way to get EasyPower to remember your device?
I guess not.  A bit annoying.
« Last Edit: May 27, 2023, 02:18:07 pm by BillyO »
