In my opinion this is the current hobbiest lab equipment Trifecta
And if you were to upgrade it would probably be something like this....
Debatable spot
Siglent SDG6022X 2CH AWG
Instek GPP-4323 4CH DC power supply
Same DC power supply.
It's actually quite funny where a discussion about power supplies may end up...
![Wink ;)](https://www.eevblog.com/forum/Smileys/default/wink.gif)
At least regarding the SDG 6000X series of waveform generators (as suggested by @Plasmateur) with the current firmware, I can only recommend to wait a little longer until the flawy start-up initialization got sorted by Siglent so the insrument would output the signal that gets diplayed on the screen... (
frst hand experience)
Otherwise, my suggstion regarding the PSU is to get a DP800 series unit (or a used "A" brand instrument with a decimal keypad). During the last week, I specifically kept an eye on what "programming" method I used when testing equipment: It was about 95% direct decimal entry of voltage /current limit before enabling the output. Any device with encoder input only would have taken me probably twenty times as long to get the parameters right.
Don't get me wrong, the encoder is still a valuable user interface, just not for initial basic testing. Moreover, the mechanical rigidity of the Rigol PSUs is something that shouldn't be neglected at a weight of 8+ kg (18lbs) of the instruments, and in my opinion Rigol is clearly in advantage regarding this subject. And above that, you can program cycles, ramps and what not for series cycling /testing of equipment. I'm not aware of any other instrument in this price range that would provide this feature (stand-alone that is). Admittedly, you can get similarly specified PSUs for less money, but if you only once need the advanced features that the DP800 series offers, the 100 USD/EUR or whatever currency you'll have to pay your instrument with, that this insrument is dearer than the next cheaper replacement, are neglible compared to the time saving the mentioned supply would provide.
Anyway, for a hobbyist starting off into electronics, any of the PSUs mentioned in this thread will do the job.
Cheers,
Thomas
