I guess I'll buy some aliexpress cheapie and see what I'll be missing
Suggest to do so because before buying something should at least understand basic type of operation and general specs. To me saying you want logic analyzer, being interested in AD2 but not in DD is just plain absurd. Unless you actually are after NA part mostly.
And why is it so?
Saleae type analyzers stream, they do not have memory. Some originals stream fast but cost too much. Clones are cheap and slow.
AD2 will stream but a laughable speed (~2MSa/s according to some forum, not checked), onboard memory is
128KbitsDD should also stream at same speed (?) but onboard memory is 2Gbit=
2097152KbitsAD2/DD have some serial trigger but AFAIK not reliable. Saleae have none when last checked.
Only large memory can serve as bandaid.
So unless doing some very basic stuff both Saleae clones and AD2 are fairly limited. However clones are cheap and AD2 is expensive + 128Kbits is in joke class nowdays.
Maybe shall do shootout someday, I have those USB boxes more than can count - but Saleae (clone) missing from inventory - maybe should check out whats all the fuss about.
