yeah bought broken fluke 45 , then repair it , it 1.00000 in slow, and 3.0000 in medium fast. medium with wide range very handy
speaking of tek\fluke
front power button don't off the unit ; transformer still on ; and large switch on back.
range jumping from high to low ; usually otherwise. jumping not as fast as i wish.
in slow - it slow ... 2.5 count , so so .. in med 20 \ sec - very nice
2x4Wire - perfectly adding probe resistance , ( should i have Fluke certified probe for the same price ? ) so marketing
AC excellence up to 900K , and sharp cut at 1Mhz - great surprise
beeper ok
too sad no caps measure
settings rudimental, min\max offset ...
Contruction \ case . i seen better design .
why no 20.0000 mV range like 8042 ?
20.000 microAmps seems have 2 ohm resistance ... that something ...
and dial display, hmmm , it slow, measure one then switch on another slow measure again - even med mode didn't help, comparing to fluke45
display itself - large easy readable.
so for used one i would say optimal around 230-250 320 if you reealy wish it ( as it an overpriced fluke ), and 350 are region of 34401
and for 320 i rather hunt for 2 x 8040A - would be same dual display
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
