Hi. I use the Rigol DG3101A waveform generator that has a frequency limit of 100Mhz. Since it came out at the same time as the early Rigol scopes and produce software generated waveforms, it seems reasonable to assume that it could be hacked to meet the 120MHz limits of its sister generator. Has anyone had a look at the firmware within this unit?
Sent from my iPad using Tapatalk
