I run the Load Dump with an SEGGER ARM Flascher and I use this Rigup Software ...
How big is the dump file and how long you dumped it? My dumpfile had a size of roundabout 65MB.
The first command was:
"./rigup scan mso1074z-s_RAM.bin > mso1074s.txt"
After that I generated the keys with these commands:
"./rigup license mso1074s.txt 0x1C001"
"./rigup license mso1074s.txt 0x1C002"
"./rigup license mso1074s.txt 0x1C004"
"./rigup license mso1074s.txt 0x1C008"
"./rigup license mso1074s.txt 0x1C080"
After that I entered the licenses.
HTH!
Cheers
hammy
List of hex values:
(CSAR = 0x1C001) Triggers
(CSAB = 0x1C002) Decoders
(CSA3 = 0x1C004) Mem-depth
(CSAJ = 0x1C008) Recorder
(CSAS = 0x1C010) DG
(CSRA = 0x1C020) 500uV
(CSBA = 0x1C040) Power Ana.
(CS3A = 0x1C080) Bandwidth (100MHz)
(CSHY = 0x1C0FF) All
