- If the source is available that can help with trust issues (but nobody will take the time to compile it, and 80% of those that do will hassle you about where to get missing libraries)
For those, who are afraid of russian hackers, I've updated a zip-archive.Now it consist of exe-file and sources. You are free to use or compile it.
The link is: http://i-hobby.org/file/go/60/
What's the problem with a flag and with a language?Mind your Language a bit will you. Your posts with a funny URL look suspicious.
A lot of hackers come from Russia or from that region, so it is not so strange that people start asking questions. If then your language flag is set to German, your profile becomes even more strange.
Just an FYI of the bandwidth of the 'unlocked DS2072a - DS2302A' .
With well calibrated leveled sine wave gens, SG503 and SG504 (TEK) using my custom made remote head for flatness <0.1dB I re-evaluated the Rigol bandwidth.
Figures of merit:
150Mhz - Rigol is still accurate matching the Vpp of the signal.
300Mhz - Rigol is down 2dB in amplitude.
400 Mhz - Rigol is down 3dB in amplitude.
I'd go with using it to 175Mhz max as reasonably accurate. Start factoring in losses past that.
This cross refernce check matches quite well with my VNA test results on the scope.
This guy does not appear to be a "hacker" in a malicious context.. He is a physician from Ukraine who moved to Germany after "the revolution". He was employed in Crimea at the time of the putsch, when the newly formed Ukrainian government banned him from continuing work in the occupied territory. From what I understand he is now a licensed MD in Germany. I don't think his profile matches a 'script kiddie' who wants to crack your PC. Just saying...
Thats exactly what I'd expect a Ukrainian hacker's German accomplice to say.
Sorry, couldn't resist.
Yeah. But No..: 404
Bad joke pal. I spent some time on Neuro's web site, looked at the content, watched some of his youtube videos, translated his story for you so that *you* can sleep well and not be afraid. and you thanked by calling me a hacker's accomplice? GFY
I run the Load Dump with an SEGGER ARM Flascher and I use this Rigup Software ...
How big is the dump file and how long you dumped it? My dumpfile had a size of roundabout 65MB.
The dump file had a size of 65.536KB and i loaded it from 0x40000000 to 0x3FFFFFF with 4800 kHz.
I have already tried the hex values 0x1C001, 0x1C002 0x1C0FF but unfortunately without success.
Perhaps it may be a problem with the current firmware?
The first command was:
"./rigup scan mso1074z-s_RAM.bin > mso1074s.txt"
After that I generated the keys with these commands:
"./rigup license mso1074s.txt 0x1C001"
"./rigup license mso1074s.txt 0x1C002"
"./rigup license mso1074s.txt 0x1C004"
"./rigup license mso1074s.txt 0x1C008"
"./rigup license mso1074s.txt 0x1C080"
After that I entered the licenses.
HTH!
Cheers
hammy
List of hex values:
(CSAR = 0x1C001) Triggers
(CSAB = 0x1C002) Decoders
(CSA3 = 0x1C004) Mem-depth
(CSAJ = 0x1C008) Recorder
(CSAS = 0x1C010) DG
(CSRA = 0x1C020) 500uV
(CSBA = 0x1C040) Power Ana.
(CS3A = 0x1C080) Bandwidth (100MHz)
(CSHY = 0x1C0FF) All
Can you not flash an old firmware then activate the keys on that before upgrading back to the latest?
Can you not flash an old firmware then activate the keys on that before upgrading back to the latest?I didn't think downgrading was possible.
If your dump is 16Kb it's too small.
a 0x3FFFFFF is 67108863 bytes
The openocd command is
dump_image mso1074zs.bin 0x40000000 0x3FFFFFF
Thats start at address 0x40000000 and dump 0x3FFFFFF bytes so if you have a 16Kb dump it's not going to work
If that is a typo and even if you meant Mb it's still too small to be sure you got everything.
If you do have a 64MB dump please ignore this, otherwise if you truly have a 16Kb dump, please try it again and be sure you get the full 64Mb+ dump
What boot loader do you have? has it been upgraded to a newer boot?
if not, try downgrading as MacBeth stated.
Downgrading isnt' possible with the DSA815 I've not heard anyone say the MS01074 wasn't down gradeable.
What is your firmware version?
Are current version DP832's hackable? If so, where is the keygen for them? How long do they take to power on in seconds?
