try to dump that and use a tool like ldrviewer to see if it actually contains a LDR stream if so - i have a nice LDR loader for ida pro that i can share.
Hi cybernet,
Please share... anything about Rigol and Blackfin. I'm quickly learning about it as I just bricked my DM3058E doing a firmware downgrade using the Rigol method of a supplied file on a USB stick plugged into it. I've flashed these firmwares before and not had a problem, but this time Murphy got me
I've been reading up on the ADSP-BF531 documentation and the Rigol binary file appears to follow the LDR format, just prefixed with a null terminated RIGOL firmware ID string. An example is the previous DM3058 firmware available
here.
I've got the 90 day trial of VisualDSP running and tried that LDRViewer application, but it doesn't seem to like the Rigol files even when I strip the header firmware string out and start on the 4 byte address, 4 byte count, and 2 byte flag immediately after it. But following the headers and blocks manually in a hex editor it seems ok.
Now, I have to re-flash using the JTAG port. I'm guessing the supplied rigol firmware minus the id string is probably ok. I only have an Altera USB blaster so had a look at the official tools and nearly had a heart attack at the prices
- is it possible to flash with the USB blaster? I also noticed an Olimex ARM-USB-OCD tool that looks reasonably priced and supports debugging so would be worthwhile for me to have a go at reversing this thing and fixing bugs that Rigol are so slow to...
I've also got an, ahem, evaluation version of IDA Pro 6.6+SDK and found a Blackfin module but haven't had much luck getting it to work, it seems to be for an earlier version
Anyway, any help much appreciated
Sorry to move off track from the DSA guys, but there is a lot of info here relevant to my DMM. Why do Rigol love the Blackfin DSP so much? It seems like total overkill for a simple DMM
Though I guess if they paid for all the licensed tools for their scopes and stuff... and their devs are used to it... maybe it makes sense?
